This Instructable will serve as an introduction to sewing with a sewing machine. I'm aiming it for an absolute beginner, and am writing this as a really basic lesson. If you're a beginner, and a step isn't clear enough, please let me know.
p.s. There are already several good instructables on how to thread a sewing machine, so I won't be including that part.
Remove these ads by
Signing UpStep 1Tips on Acquiring a Sewing Machine
If you haven't been gifted a machine and are looking to purchase your first machine, here are some hints to help you choose the right one.
a. Start by finding a reputable sewing machine repair shop.
Often they will be attached to a dealership (just like cars!). If you can find an independent repair shop, and you have a good rapport with the mechanic, you might be happier. This guy (or gal) will be straight about repairs and won't tell you to give up your old machine to buy the latest model. Also, s/he will be a good source for acquiring a good, used machine if you're on a budget. If, on the other hand you find that your local sewing machine dealer is fabulous, by all means, use your best resources and go for it.
b. Get a machine with all-metal parts.
Many cheaper model sewing machines have plastic pieces. These parts are the ones that will invariably break first. Replacement of the parts may be cheaper, but you'll end up spending far more for the labor to install new plastic parts that will break again. (SIDE NOTE: my stepmom bought me a Sears Kenmore 12-stitch: all-metal parts. It's still running strong, with only the occasional tune-up, for almost 30 years!). If the choice is an all-metal, simpler sewing machine with "only' 12 stitches and a machine with more bells and whistles (and plastic parts) for the same price, invest in the first machine.
c. When you're first starting out, consider a basic model.
In all honesty, you're likely to never require more stitches than those included with the basic 12-stitch model. If, down the road, you find your sewing becomes detailed enough that you need a more complex machine, look for a machine that'll fit those specific needs. You can then keep your first machine as a workhorse, to just do crafting, or buttonholes, or whatever. Or, you can gift your first machine to a non-profit , like your local Girls & Boys Club.
all the best
Webmaster of brothers 6000i
all inclusive resorts in florida
vet tech
i managed to teach myself to stitch all kinds of fabric except those stretchy ones.. whenever i run a stitch i realise it has undone .. how to deal with these pesky fabric types??
and hey!! thanks for every little precious instructions!!! ;-)
Sorry if this was already mentioned and I missed it, but I can't find the answer anywhere. Once you finish sewing what you want and cut the thread, do you have to knot it? I guess if the tension is right in the stitches the loose ends shouldn't matter... it just seems like they'd eventually pull out, especially where there's a lot of pressure on seams.
Whenever you start (and finish) a seam, sew forward a few stitches, then "reverse" back over them. This will "lock" down the seam's edges. Then you can snip the loose threads w/o worry of unraveling the seam.
Thanks.
Someone may correct me if I'm mistaken that this works universally ( I know that it's always been this way in my experience):
When looking at the bobbin casing, you will notice a diagonal slash where the thread comes through once you've insert the bobbin.
Insert the bobbin so that the thread comes off it in the opposite direction of the slash.
Once the bobbin is inserted and thread pulled through the casing, the bobbin will rotate in a clockwise direction if you pull on the thread.
Also, you might want to mention that the piece of metal on top of the bobbin has a screw that may be used to put slightly more tension on the thread. If that doesn't do the trick, the metal can probably be removed and bent by hand just a bit more. It is made of spring steel, which usually holds its shape forever, but sometimes an old machine needs just a little more help.
http://www.instructables.com/id/How-to-Thread-a-Sewing-Machine/
and
http://www.instructables.com/id/How-to-thread-a-Sewing-Machine_1/
