How to Sew (using a sewing machine)
Step 3Practicing Straight Stitches - Learning to Sew
  • last photo ←
You can start learning how to manipulate the fabric by first sewing in a straight line.
a. Take your fabric chosen from Step 2 and cut a 8" wide strip that is 18" long. Fold it in a half and make a crease (you can use an iron to create a more firm crease) at fold.
b1. Thread your machine (consult your manual or the other Instructables for this step).
b2. For this first bit of sewing, you can use a needle for mid-weight, woven fabric. (As for choice of needles, look to eventually having a variety of needles. Several things can determine the type of needle to use, such as the fabric choice or the type of stitch. When you're doing regular sewing, the fabric's weight determines the needles' size, and the type of fabric determines the shape of the needle's point.).
b3. Choose a medium stitch length, usually 2 1/2 or 3 (consult your manual for this, as well, since stitch length varies from machine to machine. Some have a knob, others have a multi-stage switch)
b4. Set your machine to Straight Stitch, which is usually the first stitch in your list
c. Begin with the Needle in the highest position (you should always start and end with the needle in this position) and draw up Presser Foot.
d. Draw out your Top and Bobbin Threads about 6 inches back from the Feed Dog. When you begin your first stitch, make sure you are holding onto your Top and Bobbin Threads, as they can be "sucked" into the machine on the first few stitches.
e. Place your fabric under the Needle, positioning it so the Needle will enter the fabric at a stripe near to the crease.
f. Bring down the Presser Foot (It's very important to have the foot down when sewing, since its down position is what creates the friction for the Feed Dog to move the fabric along as you sew).
g. A helpful hint when you're first learning (or if you find you need precise needle placement) is to hand-guide the first stitch in your fabric layers. To do this, use the Hand Wheel to lower the Needle into your fabric layers. Once you are more familiar with your machine, you can generally eyeball needle placement.
h. Put your fingers on your fabric, so as to guide it, down the stripe, under the Presser Foot. Press down gently on the Foot Pedal and start sewing.
This is where your training begins, to teach your fingers how to touch, grasp and hold your fabric layers as they are sewn together. Practicing "step h" over and over, using different fabrics, of different weights, with stretch and non-stretch, will get you familiar with how each type of fabric will need to be worked with.
i. Stop the Needle when it's in it uppermost position and draw up the Presser Foot (use the Hand Wheel, if necessary). Gently pull out your fabric, cut your threads (make sure to leave at least 6" of Top and Bobbin Threads hanging back, so you can have a "start" for your next bit of sewing).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:LindyGirlThay
We share our Craftsman in the Allendale district of Oakland with three cats and a lagamorph named Shug R. Bunn. I also BookCross: http://bookcrossing.com/friend/CultoftheEye
