Introduction: How to Sharpen a Center Punch
Picture of How to Sharpen a Center Punch
Video tutorial on how to sharpen a center punch. After usage a center punch can either dull or chip which does not make it mark as efficiently as it should. A center punch can be resharpened to make it functional again, there is no need to throw it away. Make sure you wear safety glasses when doing this procedure. An angle gauge can be used, but is not necessary. The more practice you get, the better you will become at sharpening center punch. I do this by free hand, no special tools are required for the procedure.
Tools/Supplies Needed:
  • bench grinder
  • center punch
  • safety glasses
Step 1:
Picture of
The tip angle of a center punch should be about 60 degrees, this ensure it will mark correctly and have a long life expectancy. Too sharp of a point will dull quickly and too blunt of a point will not make a quality center mark. When using a bench grinder, be sure to take the correct safety precautions along with wearing safety glasses.
Step 2:
Picture of
When sharpening, the grinder wheel must turn in such a manner where it'll pull the material away from the tip. The center point of the bit stays centered and be careful not to overheat it so it does not wreck the temper of the metal. When sharpening, move the center punch along evenly while spinning on the grinding wheel which ensures even wear on the grinding wheel.
Step 3: Al Done!
Picture of Al Done!
Once done, you should be left with something such as this.
Stay up to date with my latest tutorials, don't forget to FOLLOW my profile and be sure to check out my YOUTUBE page as well for all your DIY needs.
Exarmyguy (author)2017-05-16
I put the cente punch in my drill then turn in against the grinder. It makes an even grind that way.
pfred2 (author)2017-03-11
When faced with this task I made a V tool guide block for one of my bench grinders. That helped me keep the point centered.
BeachsideHank (author)2017-03-08
Pity the poor center punch, almost never thought of when tools are in need of sharpening, yet performs one of the most basic functions in the workshop. Nice to see it get the attention it deserves. ☺
4DIYers (author)BeachsideHank2017-03-08
Thank you :) Simple tool, but extremely helpful.
About This Instructable
2,568views
23favorites
License:
Bio: Car enthusiast YouTuber creating helpful tutorial videos on both repairs and customizations. Be sure to hit that SUBSCRIBE or FOLLOW button!
More by 4DIYers:How to Upgrade Your Vehicle's Exterior Incandescent Bulb to LEDTop 10 Money Saving Auto Repair Tips5 Ways How to Remove a Stuck Brake Drum
Add instructable to:
