How to Shorten Straps on a Handbag
7,293
4
Posted in CraftFashion
Introduction: How to Shorten Straps on a Handbag
About: My name is Jessie and my motto is: "Creating the Good Life from Everyday Inspirations"
Have you ever bought a bag you really really love but when you use the strap, it is just a little bit too long for you? This happens to me ALL the time! It’s exasperating! At some point I decided that I needed to figure out how to shorten straps on a handbag. This is the technique that I’ve been going with for years now and boy, does it make a HUGE difference. No more looking like a midget! No more bags slapping on my thighs! I can actually touch the bottom of my bags with my fingers.
DISCLAIMER: I should point out that permanently altering your handbag and handbag strap may void any warranty you have on the handbag, so take a look at the warranty information before you embark on any alterations.
Step 1: Before You Begin, You'll Need These Tools
You will need the following tools:
  • An awl
  • A hammer
  • A pencil
  • A piece of wood
Step 2: Marking the Straps to Measurement
Put the bag on with the strap on the shortest version possible and visually measure how short you need the strap to be for it the bag to sit comfortably on your body.
Remove the strap from the handbag (if possible) and also remove the buckle. Using a pencil, mark off where the new holes for the straps should be.
Step 3: Creating New Holes in the Strap
Place the strap (top up) on top of a piece of wood and on a hard surface (like a cement floor). Take the awl to create an initial indentation on the markings. Then using a hammer, hit the awl into the marking to create a hole.
Push the awl through the hole to create the desired hole size. Do this from the top and from the bottom, turning the awl clockwise and counterclockwise.
Step 4: Test Out the Strap!
Once the holes are set (I made 2), slide the strap back into the buckle. The buckle and holding strap should cover the holes so that your work is not visible.
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    2 Comments
    Thanks for sharing! Lovely pictures and easy to understand 'ible. Great job :)
