How to Smoke a Pipe
1,325
21
8
Posted
Introduction: How to Smoke a Pipe
Smoking a pipe is a relaxing and fulfilling way to spend an evening.
to begin you will need:
A pipe
Tobacco
A lighter
Optional things may include:
Filters
Pipe cleaners
A tamper tool
Step 1: Clean Your Pipe
Before you begin, you should take apart your pipe, throw away the used filter (filters last 3-4 smokes), and run a pipe cleaner through both pieces once or twice. Then put your pipe back together
Step 2: Pack Your Pipe
You want to pack your pipe in 3 stages.
First you fill in to the top with loose tobacco. Tamp down the tobacco with your finger or a tamper until the tobacco fills about 1/2 of the bowl.
Next, you fill the bowl to the top again. Tamp it down to 3/4.
Finally, repeat the process again.
Your pipe is now ready to light. You want to make sure that when you draw through your pipe, it feels like you are sucking through a drinking straw. If there is more flow, tamp the tobacco down a little harder. If it is difficult to draw through or no air comes through the pipe, take it apart and use the needle on the tamper to punch through the tobacco.
Step 3: Light Your Pipe
Once again, this isn't as simple as it sounds and is done in 2 stages.
First you bring the lighter to the bowl, and take about 10-15 puff, moving the lighter around in a circular motion. Put the pipe aside and let it go out. This is called a False Light. Then, using the tamper tool, gently pack down the tobacco.
Next, once again, bring the lighter to the bowl, gently puff on the pipe while moving the lighter in a circular motion, until the tobacco is lit evenly. This is called a True Light
Step 4: Smoke Your Pipe
Now you can smoke your pipe. You want to control the speed at which you smoke.
If you smoke too slowly, the pipe will go out, which isn't a big deal at, but is just a minor inconvenience. Just relight the pipe.
If you smoke too quickly, you will get an unpleasant sensation of prickling in your mouth, called "tongue bite", or worse, you could damage the pipe.
Step 5: Empty Your Pipe
After you've finished smoking, use your tamper tool (or a toothpick) to gently scrape out the ash left in the bowl. And you're done. Just lay the pipe aside in a safe place until you ant to use it again. People say that you should wait 10 hours between smoking 1 pipe, but I've seen no proof to this claim, so I'll leave the decision up to you.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    6 Comments
    controlling the speed is also important because of you puff too hard, the taste is burnt out.
    I love my pipe, and this instructable is exactly how I tell people to enjoy an evening.
    Been smoking a pipe for 8 years and this is how I pack and light! Great tips.
    Glad to hear I got it right, thanks for the feedback.
    One more item for the list of "Optional things": Fire retardant furniture covers. My dad used to smoke a pipe, usually in the living room, mom was always finding suspicious pin holes caused by the fly ash from dad's pipe around the armrests where he used to recline while reading and smoking. ☺
    I personally don't have this problem, because everything is flame retardant where I smoke, but that is a good point. :)
