3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Soap: How to
Soap: How to
  • last photo ←
Castile Soap How to:
Includes pictures and videos.
Step 1The Goods and Where to get them
The List:
1. Rubber Gloves
2. 1g Resolution scale (Amazon )
3. .01g Resolution scale (Amazon )
4. safety glasses
5. Molds (Milkyway molds
6.Soap recipe  (Lye Calculator )
7. Glass Measuring cup (Thrift Store )
8. Glass picture (Thrift Store)
9. small measuring cup plastic or glass (Thrift Store)
10. Stick Blender (Amazon )
11. Cloth towel (Thrift Store)
12. Stainless Steel Pot (Thrift Store) No Aluminum
13. Plastic or stainless mixing stick (No Aluminum )
14. Water
15. NaOH Lye (Amazon)
16. Olive Oil
21 comments
Oct 31, 2011. 7:33 PMladiebuggg888 says:
where can you get the lye locally instead of through amazon? also the scales???
Aug 29, 2011. 9:16 PMshortw says:
You did not mention how dangerous it is to handle Lye.
This should had been the first thing in warnings folks especially for those folks that never used or handle lye before.
Wearing rubber cloves and a long sleeved shirt or coat is a must!
Lye will burn your skin, from minor red skin or  in the worst case your skin could peel of your flesh, since lye could dissolve the fatty tissue right below your skin that holds your skin to the flesh.
Wearing goggles is a must!
One drop of Lye could burn your eye that you could be blind for the rest of your live.
Fumes that is created while mixing lye, water and oil has to be vented to the outside, or do your work outside.
Fumes can attack your kidneys, lungs, eyes or your nervous system and under worst cases could even kill you.
Aug 29, 2011. 9:23 PMshortw says:
I forgot to mention,
If you handle lye keep some lemon juice ready, just in case you get some lye mix on you. Pouring lemon juice over the lye mix that you may have spilled on you will neutralize some of the lye until you run to the bathroom to take a long shower.
Sep 30, 2011. 1:54 PMilike2make says:
Or if you are worried about spilling, don't do it at all.
Aug 28, 2011. 8:39 AMtacamaral says:
So, just to help out those of us who use centigrades, 90-115 F would be 32-46 C. : )
Nice instructable - my girlfriend is dying to try it.
Aug 25, 2011. 12:17 PMstar folder says:
The longer you let the soap dry, called saponification, the longer the soap will remain as you use it. This also works with purchased bar soap, remove the labels, and just let it air dry. The longer the better.
Aug 25, 2011. 8:29 AMtreynolds57 says:
Great Instructable! I learned to make soap from my grandparents and was once part of a soapmaking group on AOL. Been saving my grease, so I guess it's time to get busy! - Tony
Aug 25, 2011. 10:39 PMjiaojiao says:
oh, I once used NAHCO3 to make soaps but failed; now I know where the problem is ~
Aug 26, 2011. 12:10 AMmikolynn says:
90 to 115 degrees? I supose you are talking about Centigrades? Or Farenheit?
Thanks!
Aug 20, 2011. 5:01 PMjoen says:
Your Instructable brings back some good memories about when I was making soap at home. I used fat from the meat section at the super market and lye. However I didn't have any molds to work with so I just waited for the soap mass to thicken until I could knead it like stiff dough. Then I would form it into a brick about the width and depth of a regular bar of soap and then sliced off the finished bars about an inch thick. A couple of weeks later they were ready to use. For those that haven't tried making soap, it is a lot more fun then you might think and this instructable is as easy as it gets!
Here's a "Good Job!" for you.
P. S. All the soap recipes I have seen say you need to use distilled or pure rain water. It is not mentioned in your Instructable, I have never used anything but distilled water. Is that important?
Aug 25, 2011. 8:33 AMtreynolds57 says:
Another note: I have always noted that, with my soap at least, I don't get fully cured soap for 3-4 weeks, versus the one week noted in the directions...
Aug 25, 2011. 1:53 PMjoen says:
You're right. When I said "a couple of weeks" I should have been a bit more specific. I always made a new batch far enough ahead so that I didn't need to get to that first bar for a couple of months at least so that was not a problem. Time wise, more IS better!
Aug 22, 2011. 9:34 AMsunshiine says:
I enjoyed your ible! The soap is so pretty! Voted! Is that a lavendar field? Where is the video link? It is great that you listed where to buy the goods.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:toddsleeman
pilot/inventor + a little mad scientist epistemologist!
