How to Soften Butter Quickly
4,968
14
6
Published
Introduction: How to Soften Butter Quickly
About: I like making food and trying food!
Ever reach for the butter dish only to realize that it's empty but you need some spreadable butter right away but all you have is the block that's in the fridge.
Using the microwave to heat the butter can be problematic and warming it with hot water usually ends up melting parts of the butter. Grating the butter is another way to warm butter but it can be messy.
This quick tip will have soften butter on your toast in no time. The basic principle of warming butter with any method is to create more surface area and to work the butter.
Step 1: Materials
You will need:
  • Butter that is cold that you want to warm
  • Rolling pin
  • Plastic bag or cling wrap
Step 2: Pounding and Flattening the Butter
Put the cold butter in a bag or between two pieces of cling wrap. You can use as much or as little butter as you need. I've done this with a pound of butter and works great.
Start tapping the block of butter with a rolling pin until it starts spreading out. As it softens you can start rolling it out.
Make it as flat as possible, the more you work it the faster it will soften. You will want to remove it from the plastic and put it on a plate as once the butter gets warm it will be hard to separate from the plastic.
Enjoy!
Video on how to soften butter quickly:
Follow me on Instructables or subscribe to me on Youtube for more DIYs and hacks.
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Stick It! Contest
      Stick It! Contest
    6 Discussions
    Thanks for sharing. Much easier to control than our typical microwave approach.
    I've done this and it works great. I usually warm the plate under the hot tap while I'm rolling the butter, and that makes it even faster when I put the butter on the plate.
    My wife is usually full of so much steam by the time that I get home from work, so I just simply put it in front of her gator while she is complaining and it is soft in no time.
    Sounds interesting, but seriously, what is a gator? Sorry, I am not a native english speaker.
    vanbc
    2 years ago
    i just set my knife on the toaster. And there you have it.... a hot knife thru butter.
    This tip would also be for recipes that call for 1 stick of softened butter etc. i.e. homemade chocolate cookies. :-)
