How to Softmod Your Wii (4.3) U/E/K/J
10,409
16
4
Posted
Introduction: How to Softmod Your Wii (4.3) U/E/K/J
Ever wondered how to get homebrew applications onto your Wii without a modchip? Well, we have got you covered!
Requirements:
- Wii on system version 4.3U, 4.3E, 4.3K, or 4.3J
- SD Card (1 GB or larger)
- A computer with an Internet connection
WARNING: Softmodding your Wii WILL VOID your warranty!
If you're new to homebrew, you might want to do some internet research about it. You should know the dangers of running homebrew before installing it. Homebrew applications may have FULL access to the Wii filesystem! Use common sense when downloading applications! WiiBrew has a great list of applications you can run on your Wii.
Suggested Sites:
http://wiibrew.org
Step 1: Retrieve Your Wii's MAC Address
You'll need your Wii's MAC address to softmod your Wii.
First, make sure that you're on the Wii Menu. If you're not, exit whatever you're using. Then, enter your Wii System Settings. Scroll to page 2 and select the Internet button. Then select "Console Information". This will display your MAC address. Write down your MAC address, you'll need it later on.
Step 2: Download and Extract LetterBomb
You'll need to download LetterBomb. LetterBomb is a Wii message board message containing code to execute the hackmii installer (homebrew installer).
First, head over to http://please.hackmii.com. Then, select your Wii System Menu version. You can check your Wii system menu version when you enter the Wii system settings. It should say something like 4.3U, 4.3E, 4.3K or 4.3J. After that, type your Wii MAC Address. Make sure that the checkbox below is checked. Next, solve the captcha. Nowadays captchas are just a matter of checking a checkbox. Next, you'll have two options, cut the red wire or cut the blue wire. You can cut either. When clicked, you'll download a zip file named "LetterBomb.zip". Extract it at the root of your SD card. Your SD card root should contain a bunch of text files, a boot.elf file, and a folder named "private".
Step 3: Running the Installer
Once you have extracted everything, get back to your Wii and insert your SD card. Then navigate to your Wii message board and go one day back. You should see a message with a bomb, click it. Once you click it, a bunch of technical details will appear. Don't worry, LetterBomb is just doing what it has to do. Then you'll be presented with a scam warning. You'll have to wait around 1-2 minutes. Press 1 or 2 to continue to the installer.
Next, you'll be presented with an installer dialog. It will tell you what can be installed and what can't be installed. Install the Homebrew channel and install BootMii as "boot2". BootMii can restore your Wii if it is bricked, and can back your Wii up.
Step 4: You're Finished!
That wasn't so hard, was it? Now, have some fun with your softmodded Wii! You can backup games, install emulators and much more.
Tell me what homebrew apps I could use, I appreciate every response!
  • WiktorK9 made it!
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
3 Comments
Yep it works like a charm :D now it's backing UP :)
Hello, I followed your interactions step by step and I was unable to complete the installation.. I downloaded the letterbomb software using my MAC and I have a 8gig SD card.. Could it be my SD card? Help please, I'd really like to have some help on this..
Thanks
Maybe it is. I can install without problems.
