How to Solder 3.7v Lithium Ion Cells
Published
Introduction: How to Solder 3.7v Lithium Ion Cells
About: A science freak teen
Usually lithium ion cells are used in laptop batteries. They are hard to solder that is why they are welded by spot welder, which requires a transformer. But today I bought you guys a solution by which you can solder a 3.7v lithium ion cells.
Materials Required
Bevel Tip For Solder ( You can get it on hardware store or you can make your own by cutting the pointed tip and rubbing tip on whetstone or concrete) See Image
Solder Iron
Wires (Better to use Copper flex Wires) See Image
Step 1: Heating Battery Tab
Heat the battery tab for 10 seconds by placing solder on it.
Step 2: Applying Solder on Tip
See Image
Step 3: Applying Solder on Wire
Step 4: Soldering Wire With Battery
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
