This Instructable is a collaboration between leonardo ismael (aka Oscar - Instructables' newest intern) and noahw that was made possible by the good folks over at Cool Neon. In addition to the step-by-step instructions that are in this Instructable, you can also check out the easily printable/portable .pdf directions that are attached to this step.
Remove these ads by
Signing UpStep 1: Prep the End of the EL Wire
Some wire may have its' ends already stripped and prepared for you. If your wire has already had its' ends prepped then just skip this step.
First you will start with the bare EL wire pictured below. There are lots of different pictures in each step so click on each of the images below and follow along with the numbered steps.
Second picture:
Now grab a wire cutter and strip off the colored PVC sleeve around half an inch from the end of the wire. Make sure that you do not cut all the way in, just strip off the colored PVC covering.
Third picture:
Now you will see a thinner clear PVC sleeve covering the core wire.
Fourth picture:
Cut the clear PVC sleeve off, but be very careful not to cut too deep because two very small and fragile wires called angel wires are right underneath it.
Fifth picture:
Now that you have both sleeves off, you will notice that there is phosphor coating on the thicker center wire. This is not a skin so do not cut it off. Instead, carefully scratch or sand it off with some sandpaper or a razor blade.
Visit Our Store »
Go Pro Today »
http://www.amazon.com/JVCC-CFL-5CA-Copper-Conductive-Adhesive/dp/B000UZ8SJK
So you know how I found it, I used this website:
http://www.google.com/search?q=amazon+copper+tape
If Amazon.com is not available in your area, you will need to improvise. ..
I noticed this tape is often touted as "slug repellent tape" so you may also find it at a local gardening or nursery store.
Have you tried any of the big box hardware stores (homedepot or lowes)???They sometimes have things like that in the electrical section...Or maybe a car parts store that caters to the high end upgrading; EL wire is often used in cars...Then there is always (if you live in a town big enough) an electrical supply store (the kind of place that has plugs and switches that can fit anything)...
If none of these places have what you are looking for...They might be able to point you in the right direction to the place that does...
I hope you have already found your wire and if you haven't I hope this helps...
Happy building and good luck...
