How to Solder Easily
Introduction: How to Solder Easily
This is a easy guide to solder some components , this can be used for kids to begin in electronic.
Step 1: Materials
For this projects the materials are:
  1. Soldering iron.
  2. PCB.
  3. Headers 2 pin.
  4. Tin.
Step 2: Header
We proced to put the header in their respective pad.
Step 3: Solder
Now we put the solder and the tin in the pad, to have a better result you can use a solder paste.
Step 4: Finish
You can clean now with a little brush.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    What do you mean by item 4. Tin.
    You need a soldering iron, solder and flux or flux cored solder, a circuit board and the components you are fitting.
    sure the component leads and the solder pad are clean, if the solder
    bubbles when you apply it, it is usually because 1 or the other or both
    are dirty. That can cause dry joints/bad connections.
    Make sure
    you heat the component lead and the solder pad equally before applying
    the solder. If one is cooler than the other you can get dry joints/bad
    You would also get a cleaner result if you used flux cored solder instead of seperate flux and solder.
    this is no instr.
    needs a lot of adjusting,but its a try.
    Wwhat kind of soldering iron do you have there with a fume extractor?
    My suggestions Use 60-40 solder wire and good quality soldering iron
