How to Solder LEDs Using a Simple Jig
Published
Introduction: How to Solder LEDs Using a Simple Jig
About: It's not important who I am or what I know. What is important is what I can teach you.
Holding LED's in place for soldering can be a bit tricky. So I invented a simple jig to make the process easier. I will explain how to make duplicates of the jig, but it is real easy to make just one. An alternative method is to clamp two pieces of wood together, then drill between them.
Materials Required
Any block of wood over 25mm square
Led
Wire
Solder
Masking Tape
Tools Required
5mm Drill
Drill
7mm wide Screw Driver
Hammer
A saw of some kind
Soldering Iron
Step 1: Making the Jig
Step 2: Using the Jig
Step 3: Feedback
If you have made the jig and find it useful, please share your experience by clicking "I Made It!", "Add Images", "Post" or "Make Comment".
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    cheers koko.
    Obviously switch to a 3mm Drill for smaller LEDs.
    I hope it has made life easier for you.
