3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Solder Videos: Why is soldering difficult sometimes?
This is another "How to Solder" instructable, but it also attempts to get at why soldering doesn't go easily sometimes. On the following pages, there are also numerous pictures showing good technique, good and bad joints, and some tools of the trade that you may not find in your local RadioShack. If you've ever wondered what wattage iron to get, the 3rd step has a video showing how some irons of different wattages fair on a couple soldering tasks.
Here is my list of the top reasons soldering doesn't work well (looking forward to your opinions on this):
1. Soldering tip has oxidized (turned black) and solder won't stick to it. This happens when the tip is left bare while on--a naked tip will quickly oxidize at hot temperatures. The best advice for preventing this is to glob solder on the tip every time you set the iron down. Weller (high-end iron manufacturer) actually recommends holding solder against a new tip the first time you turn it on so that the solder will melt and cover the tip the very instant the it gets hot enough. One of the best guides out there that emphasizes tip care: Weller's HowTo
2. Bad technique: applying solder to the iron, letting it sit there for a while, and then trying to carry it over to the joint. If you let the solder sit on the iron, the flux quickly boils off (the fumes are from flux, not the lead). And without flux, soldering becomes almost impossible. Flux removes oxidation from metals, and it's crucial because solder won't stick to oxidized metals, and metals oxidize very quickly at soldering temperatures.
3. Not enough heat: A 15 Watt iron is fine for small chips, but any larger connectors or wire bigger than 16 gauge will cause problems. 25W-30W is probably fine for most hobby applications. Is there any risk to getting a 100W iron? Wattage is separate from temperature, right? ... depends on the iron. Watch the video on the next page.
4. Dirty or oxidized parts: Bare copper oxidizes relatively quickly (this is why most components are tin / lead coated), so older parts or bare copper that has been exposed for only a week or two can require a light sanding (pink erasers are great) or stronger flux.
Shameless plug: This instructable is an except from a larger guide with many more pictures found here: www.CuriousInventor.com/HowToSolder. There is also a desoldering guide, a review of the cold heat iron, and advice for choosing solder / flux types. And, of course, a store to buy stuff :)
Thanks for any corrections / feedback.
Step 1Good Technique
Good Technique
You want to hold the iron tip to get as much contact between the tip, component, and board as possible. Add a small amount of solder in between the tip and component to act as a heat bridge--this may not be necessary if enough solder is already on the tip when you tinned it.
Finally, add solder to the opposite side of the joint. Solder will run towards the heat, so this helps to spread out solder, and also ensures that the components were indeed hot enough for solder to melt and adhere to them.
79 comments
1-40 of 79next »
Jul 12, 2009. 4:42 PM=D says:
i have an 80W soldering iron with a chisel tip (Weller brand) that i bought for $20, but i find that it's too hot and the tip is too thick. Could i stick the tip in a lathe and grind it down so it's like a cone shaped tip, or would that ruin the tip? and when i was soldering connections on a plastic battery pack, the plastic started melting..... should i just get a cheaper soldering iron with less watts?
May 21, 2010. 5:37 PMstatic says:
Too bad the link results in a 404 error message. I understand that being an instructor or a student at a tech university, a small business partner, and life in general forces one to manage their online time. Having said that IMO it isn't cool to direct responses to comments that include questions and reader of those  who also may benefit s from the answer away from  an instructable.
May 24, 2011. 5:43 AMearlye says:
404 again. You ought to consider setting up some permalinks that redirect to the correct location when your site changes again.
May 21, 2010. 6:57 PMstatic says:
Great, thanks. Not knowing what you recommended a held off in pointing out some tips are plated and sanding or grinding them will ruin them. In the event your group ever revise your instructions that would be something to include. along with that "loose" tips can cause problems. My suggestions to =D where going to be to get an iron in the 40-45 watt range and get a new tip for the 80 watt iron, and make sure it was tight when installed to see if it will tin, if not use a light dimmer to make a simple control to reduce the heat, to see if will tin then. The simple control will turn that 80 what monster into a dual purpose iron, and will be usable for any iron purchased in the future. Nawadays the digital readout infrared thermometers. make calibrating the simple temp controls much easier.
Jul 13, 2009. 5:00 PM=D says:
thanks a bunch! I'll just go out and buy those el cheapo soldering irons, one of them i found for $8 and it's from my favourite electronics part store, so i'm sure it's fine. thanks again!
May 15, 2010. 2:07 PMcdousley says:
now i understand
great videos
Feb 22, 2010. 6:21 PMReverendSapp says:
As a person who has had hit and miss luck with soldering, I am happy I stumbled upon this video. Your video helped me to realize all the mistakes I have made in the past, I still have a way to go I'm sure but this is an excellent start. Thanks!
Feb 21, 2010. 5:29 PMjethrow815 says:
Question, I have a new Weller 40W chisel tip, using Oatey 40tin 60lead rosin core.
Cant tin the tip if my life depended on it.
 the solder just rolls off the tip in little perfect balls onto the mat
any ideas?
thank you~
Dec 7, 2009. 4:31 PMcorsi says:
bravo well done. the videoo helped alot. it is easy to get lost when there is only text. good job i learned how to solder properly now.
Sep 17, 2009. 10:24 AMDonnn says:
YOU are the MAN !!! I can and do solder quite a bit but you have really done a great job of explaining the reasons for all the innate things we do to get a good joint ... and the why not toos as well this is by far the best Ive seen...
Aug 14, 2009. 3:39 PMlost2010 says:
wish i would have watched b4 attempting to mod a perfect 60$ 360 controller :( my iron is like lumpy and brown and has actually formed a hook shape some how.
Jul 24, 2009. 10:33 AMguy90 says:
Great video! thank you
Jun 28, 2009. 12:01 AMcaredo says:
Thanks for this. I'm brushing up on the basics again and this really helped. It also helped that the narrator for this video was easy to listen to and wasn't droning in a monotone. Very well-done.
Jun 6, 2009. 7:21 PMfranklinonline says:
i kinda think thats too much solder
Jun 19, 2009. 3:38 PMfranklinonline says:
if you make the blob too big you have the risk of connecting ajacent ones, a short circut is not good and will cause problems and it doesnt look good so it would probably be good practice to make blobs just big enough to make the connection so you dont cenect things
Apr 9, 2009. 3:27 AMonecooldudemiester says:
i found a de-soldering pump at the pound shop
Mar 18, 2009. 2:30 AMjames.mcglashan says:
were can i get the solder vacuum
Mar 11, 2009. 7:15 AMMikeDaMan says:
wow this answered most of my questions! Thank you soo much!
Mar 7, 2009. 2:17 PMLike2Learn says:
I didn't know much about soldering at all, until I watched this video. It was great. Now i just have to figure out what all to get to get started.
Feb 15, 2009. 5:43 AMMetalcaster14 says:
YES! finally! why couldn't all the other tutorials I've seen be so simple yet so helpful thanks great 'ible
Feb 8, 2009. 9:21 AMbuckaroo169 says:
Wonderful set of How-To-Soldier videos. I've been doing these procedures for about 30 years. It took me a decade or so of trial and error and research to get this much information. Although it does take lots of practice. KUDOS to you guys!!!
Jan 13, 2009. 4:02 PMcd41 says:
Haven't soldered once wanted to find out about it before i jump in(i do have a iron though!)
Jan 10, 2009. 6:42 PMhydrnium.h2 says:
Thanks for all this help, I just started Soldering and I've been having a hell of time trying to figure it out.
Jan 10, 2009. 6:14 PMkbitz says:
Cheers man, fixed my noobish soldering :D
Jan 6, 2009. 2:31 PMandrew101 says:
even though i solder alot this is very helpfull. alot of it i knew butit gave me better teqnique
Dec 3, 2008. 7:15 PMjohnpombrio says:
http://www.amazon.com/XYTRONIC-AUTO-TEMP-379-SOLDERING-STATION/dp/B0002UU8YQ/ref=sr_1_1?ie=UTF8&s=hi&qid=1228360382&sr=8-1
Auto-Temp 379 soldering station. I found that 90% of my troubles soldering is that the iron is NOT HOT ENOUGH. When I finally sprang for this dirt cheap station, ALL of my issues went away!
Nov 27, 2008. 7:27 PMtimmy1234s says:
so should i get a soldering station that goes from 5-40 watts or 5-80 watts. I am going to use it for general use and for circuit boards. Also, the station can be controlled, it is the WLC100 from Weller
Nov 28, 2008. 4:30 PMtimmy1234s says:
Thanks. By the way, do you think the tips that are included in the Weller WLC100 soldering station would be sufficient to do general soldering and circuitry?
Nov 29, 2008. 10:48 AMtimmy1234s says:
Thanks. This instructable is good and thanks for the info.
Nov 12, 2008. 4:06 PMcowscankill says:
So if I need to add flux, when do I add it?
Nov 19, 2008. 7:21 AMcowscankill says:
I asked because my solder doesn't have flux in it. Old stuffs.
Oct 1, 2008. 3:34 PMkog103 says:
First off, brilliant Instructable, it is extremely helpful. Secondly, instead of using the alcohol dispenser and pump to clean the joints, could you use alcohol wipes instead?
1-40 of 79next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:CuriousInventor.com
Interested in soldering techniques, electronic music instruments, arduino.
