How to Solder in 30 Seconds
 by guyfrom7up
video How to Solder in 30 Seconds
This is a brief (very brief) tutorial of how to solder. Due to the lack of time, soldering through hole components to circuit boards are only explained. This is one of the most common types of soldering for DIYers like in the Instructable community.
klee27x says: Aug 12, 2009. 10:46 PM
Hehe. I love soldering guides. If I can add my 2 cents, I'd suggest you don't wipe the tip off before putting the iron away. Always put fresh solder on it right after you wipe it. So if you're lazy, then only wipe it right before you solder something, not afterward.
zoltzerino in reply to klee27xAug 29, 2009. 4:03 PM
if you leave an iron to 'dry out' (leave it switched on with no solder on the tip) it relly damages the iron because of the oxidisation. obviously this happens anyway but heat speeds up chemical processes. I built a simply standby switch / extension lead / crude heat controller using a cheapo dimmer switch ( when one is not using the iron simply turn the heat down).
lemonie says: Aug 20, 2009. 11:23 PM
Hey man, it's solder with an "l" not "soder".
L
guyfrom7up (author) in reply to lemonieAug 21, 2009. 12:13 AM
apparently in North America we say it "sodder" while the rest of the world calls it "soul-der." so I guess it's an american thing?
lemonie in reply to guyfrom7upAug 21, 2009. 11:50 AM
It must be, I heard it once before, but it's not often you hear people speak on this site. Is this just a word-of-mouth thing do you think? L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
