How to Solve "The Cube" + Tips and Tricks For the Rubik's Cube
 by ranaakamarth
This first half of the Instructable will teach you how to solve a Rubik's cube using one of the most simplistic methods possible. You will only need to memorize about 5 or 6 algorithms.
If you can already solve a Rubik's cube in about a minute then visit This site for a better solution that has been clocked to about 10 seconds.
If you have a move that you are having trouble understanding I'll be happy to email you with a better example. If that still doesn't help I'll be happy to upload a video of it onto this instructable.
And.... No... I didn't speed up any of my videos.
EDIT: I now use the Fridrich method, and my average is 32 seconds and my personal best is 24 seconds.
Comments are appreciated!
Step 1: My Cubing History
(You really don't have to read this. now that I look back at this I think I should just delete this page...)
The first time I ever really saw or used a Rubik's Cube was back in 2005 in my 6th grade advanced science class. Our teacher had several Rubik's Cubes to play with while we were waiting for class to begin. Since it was an advanced class and everyone was more or less inclined to mental challenges, like puzzles, we had to almost fight over the cubes. Everyone in the class was amazed when someone finished a side. Since it was such a challenge just to get to use a Rubik's Cube I decided to go to WalMart to buy one for my self. When I took it home to try to solve it I was amazed at how complex and addicting the little puzzle was. One day I decided to take my cube to church. While I was at church that day I found a man who could solve it in about 3 minutes. I was amazed that it was actually even possible to solve them. I finally decided to ask him if he would teach me his method. Over the next month he would teach me a step every Sunday and write it down on a piece of paper so I could practice it every day.
I was very excited the first day I solved it. I stayed up late mixing it up and solving it. The next day I showed my teachers at school and they were amazed. (o.k., now to skip ahead a bit...)
When the summer came I stopped solving the cube. During math class in 7th grade my 6th grade Social Studies teacher brought her whole class to watch me solve the cube. Since it had been a while since I last solved it I forgot a couple algorithms so it took me a lot longer than it had before. I was very embarrassed that i could barely solve it. So when I went home I went through my sock drawer and found my notes and started to memorize the method again.
Once I got to school I could solve the cube in about 2 minutes. I then started to learn the Petrus method but discontinued using it because it was too hard for me. I picked up some key tips while learning the method though.
I've recently started a Rubik's craze at school now that I've gotten sub-minute times with this method.
My personal best solve is 29 seconds with a method similar to this, and my average with that method is 35 seconds. My best solve with the method on this instructable is 38 seconds. I'm currently learning the Fridrich Method (the one clocked at a record 10 seconds).
I can also solve a Pyraminx with a personal best at 11 seconds and an average of about 17 seconds. I can solve a Megaminx in about 10 minutes.(I don't practice much) a K-8Ball in 38 seconds (Similar to 2x2 Cube). A Dino Cube in 34 seconds (Discontinued sales, i used an applet on the internet). And a Twin Cube in about 2 minutes 30 seconds. I invented the Twin Cube. Its basically two Rubik's Cubes connected by the corner. ( I just sawed to corner pieces in half and glued them together)
First image is a random H (for history)
Second image is of a Pyraminx
Third Image Megaminx
Fourth Image K8Ball
Fifth Image Dino Cube Applet
Sixth image Twin Cube
This is a video of me with my regular method. I timed about 40 seconds.
The method I used is almost the exact same except for last layer. Instead of getting yellow cross, permuting edges, permuting corners, orienting corners.
My method for last layer is: get yellow cross, permute corner, orient corners, permute edges.
Step 2: Terminology and Frequently Asked Questions
Terminology
There is some terminology you will need to know in order to understand this instructable. Here are some words to know.
Corner - a physical plastic corner piece. Has 3 stickers.
Edge - a physical plastic edge piece. Has 2 stickers.
Piece - A corner or an edge.
Sticker - One colored sticker. There are nine on each side. You know what I mean. (hopefully)
Side - one of the 6 sides of the cube.
Layer - the cube consists of three layers (top/middle/bottom).
This is a 3-dimensional concept, as opposed to "side" which is 2-dimensional. The "green layer" is the one with the green center.
Twist, twisted - how a piece is oriented. A corner can be twisted in 3 different ways, an edge in 2.
Turn, turning - the physical act of rotating a side.
Orient- to twist or flip a corner or edge.
Position (noun) - a space of the cube, occupied by one piece.
Positions don't move, pieces move by occupying different positions. For example the red-white edge can be in any of the 12 edge positions, and it can be in the correct (red-white) position but wrongly twisted.
Position (verb)- to put a piece in its correct position.
Permute, Permute- to switch cubies while leaving them oriented the same.
There are a few questions that have been asked over and over through emails from various people so I want to post FAQs about them.
Q: What are the gray stickers in your example?
A: The gray stickers signify that the color of that sticker is irrelevant.
Q: When you say 2 Times which way do you mean to turn it?
A: It really doesn't matter which way you turn it. Two times clockwise is the same thing as two times counterclockwise.
Q: Where do you buy good Rubik's cubes?
A: I bought mine at Rubik's.com under the DIY section. With those cubes you can adjust the screw tension. The $8.99 ones with lube are very good. The lube makes your cube turn like a dream. If you want to purchase 2x2 cubes or other sizes try this site. If you want other puzzle shapes like the Pyraminx go here. Also Ebay some times has good and rare puzzles just search for "Rubiks".
Q: I have a fairly good cube but want to lube it. Do you know of any websites where I can purchase lube cheap?
A: This Website has lube that is identical to the stuff sold at Rubik's.com but cost a fraction of the price. Also NEVER USE W.D.-40!!!! IT DESTROYS YOUR CUBE!!! I put W.D.-40 on my first Rubik's cube and it didn't last me a year. The centerpiece broke in half from speedcubing. The W.D.-40 seriously weakens the plastic.
Q: What are the Official (and Unofficial) World Records?
A: Try Speedcubing.com they have many resources plus links to the records at the top of their web page.
Q: What exactly does middle: up mean? or middle: left?
A: Here are some graphics at the bottom that i hope will explain the moves.
Q: Are the Rubik's Cubes popular enough to have any forums or a place where I can talk to other Rubikian Fans?
A: Try http://twistypuzzles.com/ they have a large forum. The website also features a puzzle database, price guide, and articles to describe puzzle building.
Q: I'm having trouble understanding the Left: "Up" and "Down" concept. Can you illustrate the turns better?
A: Heres a video explaining the basic turnings.
Step 3: Getting A Cross On the First Layer
First begin by getting a cross on the top. (I prefer using the while as top.) Here are some examples of piece placements and the fastest ways of putting them into place. When you get the cross you must put the edges in correctly.
You by no means need to memorize all these cases. They are just here to help people who have no idea what they are doing.
Example 1
Front: Counter Clockwise
Example 2
Right: Down
Bottom: Clockwise
Right: Up
Front: 2 times
Example 3
Bottom: Clockwise
Front: 2 Times
Example 4
Middle: Clockwise
Bottom: Counter Clockwise
Middle: Counter Clockwise
Bottom: Clockwise
Middle: Down
Middle: Up
Bottom: Clockwise
Middle: Clockwise
Bottom: Clockwise
Example 5
Top: 2 Times
Example 6
Front: 2 Times
Bottom: Clockwise
Left: Up
Front: Clockwise
Left: Down
Example 7
Middle: 2 Times
Bottom: 2 Times
Middle: 2 Times
Step 4: Placing the Corners on the First Layer
In this step you will be placing the corners of the white side. (or what ever color you chose to get the cross on) Remember to place the corners in their correct spot. I will provide some more examples for those who just don't understand it so well. These are by no means necessary to memorize.
Example 1
Front: Clockwise
Example 2
Middle: Up
Front: Clockwise
Middle: Down
Example 3
Right: Down
Bottom: Clockwise
Right: Up
Bottom: 2 Times
Front: Clockwise
Bottom: Clockwise
Example 4
Left: Down
Left: Up
Bottom: Clockwise
Middle: Up
Front: 2 Times
Middle: Down
Example 5
Right: Down
Bottom: 2 Times
Right: Up
Bottom: 2 Times
Front: Clockwise
Bottom: Clockwise
Step 5: Placing the Middle Layer Edges
First before we do this step we must flip the cube over so the yellow side is on top and the white side (first layer) is on bottom.
In this step we will be placing the edges in the middle layer. (The row of cubies in between the white and yellow on most standard cubes). There are 3 algorithms to do this. It is basically just one algorithm. One of them is a mirror of the other, and the other one is the algorithm repeated twice with one extra turn. First look at the last layer and find a piece that goes in the middle layer. Then look at the color of that piece that is on the top (yellow side) Turn the top side so that the color is across from its side. (refer to first image)
Next look at the other color of the edge piece. Hold the cube so that the color that you saw is on the front. Now look to see if the cubie goes in on the left or right of that side. If it goes in the right (refer to second image) then do the move titled right. If it goes in on the left (refer to third image) then do the move titled left. If the piece needs to be flipped (refer to fourth image) do the move titled flip.
Right Move
Right: Up
Top: Counter Clockwise
Right: Down
Front: Clockwise
Right: Down
Right: Up
Left Move
Left: Up
Top: Clockwise
Left: Down
Left: Down
Front: Clockwise
Left: Up
Flip Move
Right: Up
Right: Down
Front: Clockwise
Right: Down
Right: Up
Right: Up
Right: Down
Front: Clockwise
Right: Down
Right: Up
(or if you need help memorizing that)
Right move ()
Right move ()
Step 6: Getting a cross on the Last Layer
In this step you try to get a cross on the last layer. (yellow side) There are 4 cases of edges. All the cases use the same algorithm but the cube is oriented differently.
Example 1
Hold the cube so the white side is on the bottom and the yellow side top. It doesn't matter which side is the front. (refer to first image)
Example 2
Hold the cube so the white is on bottom and the yellow on top. Make sure the --- on the top is parallel to your body. (refer to second image)
Example 3
Hold the cube so the white is on bottom and the yellow on top. Make sure the half plus sign is in the close, right, corner(of the top). (refer to 3rd image)
Example 4
Congratulations you have finished this step. Go on to the next one. (refer to fourth image)
Move
Back: Clockwise
Top: Clockwise
Left: Down
Left: Up
Back: Counter Clockwise
Note: the back turn is turning it as if you are holding the back side as the front. That does not mean that you solve it with the back on the front though. I might upload a video of what I mean.
Views of the top.
Step 7: Permuting the Edges
In this step you will permute the edge Last Layer Edge cubies. This move leaves the cubie on the front side alone and switches all the other pieces counter clockwise.
If none of the pieces are in the right place rotate the top until at least one edge is in the correct place.
(refer to the first image to see how the pieces are swapped.)
Some times when you do the move it still doesn't work. Here are some positions that may require a different way of executing the move. Here are the positions.
Example 1
Do the move with the right one of the two solved pieces to the left of you. After you do the move turn the top clockwise. (refer to second image)
Example 2
First do the move with the front as an unsolved side. Then turn the top 2 times. Next turn the whole cube clockwise then do the move again. Then finally turn the top clockwise. (refer to third image)
The move
Right: Up
Top: Clockwise
Right: Down
Top: Clockwise
Right: Up
Top: 2 Times
Right: Down
Step 8: Permuting the Corners
This step deals with permuting the corners and putting them in place but not having them oriented correctly. First you must find a corner that is in the correct position. If there isn't one, do the move on a random corner until a piece is in the correct place. This move leaves the top left front corner piece in place and switches the other corner pieces counterclockwise. Remember, make sure you permuted them correctly before moving on to the next step.
The Move
Right: Up
Left: Up
Top: Clockwise
Right: Down
Left: Down
Top: Clockwise
Step 9: Orienting the Last Layer Corners
Congratulations!! You have made it to the last step without brain damage!(hopefully)
In this step we will be twisting the corners to solve the cube. First before you do the move you must turn the cube so the white is on the right and yellow is on the left. (Last layer on left. First layer on right.) Then rotate the cube so an unsolved cubie is in the top left front position. (Remember keep white on right while you do this.) When you do this move you must repeat it either two or four times. To tell how many times you need to do the move. Do the move that was in the top left front position has the yellow sticker facing the yellow side (correctly oriented) WARNING!! THE REST OF THE CUBE WILL BE SCRAMBLED!! THIS IS OK!!! Once the piece is twisted correctly turn the left side until another unoriented piece from the last layer is in the top left front position. Then do the move again. Repeat this process until the cube is solved.
Move
Right: Up
Right: Down
Top: Clockwise
(2 times or 4 times)
Congratulations!!! Cube Solved!!!
I'm adding a new video soon!
Step 10: How To Lube Your Cube
Lubing, or lubricating, your Rubik's cube is an important part in getting faster times. It enables you to use finger tricks without breaking your fingers, and turn it without getting Carpal Tunnel Syndrome or "Cube Thumb". Some lubes make your cube turn so good you could turn the sides with your tongue (eww).
On this part of the instructable I will teach you how to lube your cube.
Step 11: Buying The Lube
You can purchase silicone lubricant from Rubik's.Com for $9 for one syringe full. Or you could buy the exact same product 30 syringe fulls from CubeLube.Com for $8.
Since we all like to get the most for the cheapest price I will teach you the cubelube.com method. First click on the link near the top or type cubelube.com then click on products. Next select the product you want and click 'add to cart'. Then click checkout. Next fill out the form and submit. Your lube should arrive in around a week. After the lube arrives go to step 2.
Step 12: Applying the Lube
Next we have to apply the lube. This part is very easy. First turn the top 45 degrees (It doesn't have to be exact). Next stick your thumb or a butter knife under the edge piece and lift up. You should be able to pull out the piece. After you take out the edge piece take the cap off the syringe and place your palm on the pump and middle finger and pointer finger on holds then slowly push until some silicone lube comes out. You do not need a lot of silicone, if you put to much on it wont dry up and will leak out when turning the cube. After you place a small amount of silicone on the cube place the edge piece back on. After you place the piece back on randomly turn to cube to work in the silicone. You should see an instant increase in your turning speed. Watch the video if you do not understand.
Step 13: A few "Pretty Patterns"
Due to some requests in the comments and I think it would make it an over all better instructable dealing with Rubik's Cubes. Since people said they were having trouble with pretty pattern explanations from other sources I'll include videos to go with them. Watch the video to find out how to undo the patterns also.
First Pattern "Circle around dot."
In this pattern it may look like the centerpieces are changing around the edges and corners. Since centerpieces don't change position relative to each other it's just the edges and corners moving around the centerpieces.
(Picture one)
Move
Middle: Up
Middle: Left
Middle: Down
Middle: Right
Second Pattern "X marks the spot."
This takes all the edge pieces and swaps them with the ones opposite their original position. To make that easier to understand say you have a cubie in the Front Left position. It swaps it with the cubie in the back right position. And the cubie in the Top back position swapped with the bottom from position.
(Second picture)
Move
Middle: Up 2 Times
Middle:Left 2 Times
Middle:Clockwise 2 Times
Third Pattern "I C you."
This pattern basically takes the cubies on the bottom layer and swaps them across the side. So the cubie on Bottom Front swaps with bottom back and Bottom left swaps with bottom right. It makes 4 c's if you turn the cube on the side.
(See third image)
Move
Right: Up
Left: Down
Top: 2 Times
Right: Down
Left: Up
(Turn the cube 1 time clockwise so the side that was on the left is on the front)
Right: Up
Left: Down
Top: 2 Times
Right: Down
Left: Up
Fourth Pattern "I, I Captain"
In this pattern It is basically the same as "I C you" Except it swaps the cubies on the top layer AND bottom layer in the same way. It looks like alot of I's if you turn the cube on its side.
(See fourth image)
Move
Left Up 2x
Bottom Right 2x
Left Up 2x
Bottom Right 2x
Left Up 2x
Right Up 2x
Top Right 2x
Right Up 2x
Top Right 2x
Right Up 2x
Top Right 2x
Left Up 2x
1-40 of 121Next »
majorson says: Oct 24, 2011. 1:41 AM
Nice guide,
Actually learnt from this website, it has a really good rubiks cube solution guide  and some really good tips :)
Rubik's Cube solution for beginners
Rubik's Cube Tips
watch his 7.63 Rubik's cube solution , increadible!!
Good Luck!
builderkidj says: Aug 2, 2011. 1:09 PM
My brother has had one for about 7-8 years and its still unsolved. :P
sharkstun97 says: Apr 10, 2011. 9:25 AM
i find it easier in step six to turn the cube 90 degrees to the left and do this.
Left: Down
Top: Clockwise
Front: Clockwise
Top: Counter-Clockwise
Front: Counter-Clockwise
Left: Up
i only find it easier because you dont have to do a back move
lubixcube says: Jul 9, 2010. 12:50 AM
You can also increase your speed by lubricating it. Try lubixcube.com
twonkie12 says: Feb 13, 2010. 1:37 PM
i love the tip for the  circle around dot i amazed my freinds with it and they think im a pro but im not. tiry going to this website if you are having trouble with this  instructaable www.videojug.com/interview/how-to-solve-a-rubiks-cube-in-under-a-minute. the guy is a professional and he goes kind of normal speed but it is a good video.
lukeD says: Dec 2, 2009. 10:51 AM
go to this site. The site is Dutch. but the program is English and works very well.
http://home.kpn.nl/rubik/kubus.htm
manish.mania.001 says: Oct 9, 2009. 5:33 AM
m havin a problem in solvin step no. 6 plz help me
manish.mania.001 says: Oct 9, 2009. 3:35 AM
PLZ CHANGE THE VIDEO N ADD A SLOWER ONE, i'M HAVING A PROBLEM IN SOLVING WEN THERE ARE SEVERAL HALF PLUS SIGN APPEARED
PLZ HELP ME OUT
bighead5454 says: Jun 24, 2009. 4:18 PM
do you play runescape or sumthin cause i think i heard some runescape music
dustin_virva says: Apr 16, 2009. 12:56 PM
ok now iv read most of this its too confusing i dont get most of it and its driveing me nutz that i can't solve this rubix cube lol tho i just got it like few days ago if you could like upload a video going slowly turn by turn on here that would help me and im sure some others ALOT =D
colethemle777 in reply to dustin_virvaMay 17, 2009. 4:05 AM
if you cant solve it then use the online rubiks cube solver
poolio says: May 7, 2009. 7:42 PM
I mixed my friends rubic cube up for april fools day and he couldn't figure it out so he asked me to fix it : ) LOLs
ranaakamarth (author) says: Jun 26, 2007. 1:48 PM
are you holding it with the white on the top? and the orange on the front like in this image?
C:\Documents and Settings\Owner\My Documents\My Pictures\lamecube.bmp
ofamountain in reply to ranaakamarthMay 5, 2009. 12:51 AM
I'm frequently coming to the very last move, where all colors are matched except a single cuby that's flipped. Performing the algorythm results in the last layer completed, while the initial two are now mixed. I keep running into this problem, or similar ones where working through the algorythm results in a lower left front cuby out of place. The out of place cuby is unaffected by the algorythm, which leads to further mixing of the cube.
ranaakamarth (author) in reply to ofamountainMay 6, 2009. 1:25 PM
It should be impossible for only one cubie to be twisted or flipped. If this is the case then someone has either taken off the stickers or taken it apart and flipped a cubie. Just simply take it apart (instructions to do so are under "Applying the Lube"), flip the rogue cubie, then snap it back together. This should fix the make the cube possible to solve again. There are really only 6 possible ways the corners can be oriented on the last step (excluding mirrors). These are shown from the top looking down on the cube in this picture. The yellow is the last layer and gray is an undetermined color. If the pieces are in any other order than this the cube was probably taken apart.
JamesRPatrick in reply to ranaakamarthJul 8, 2007. 1:47 PM
That is an awsome drawing of one of Rubik's cubes. And where did the purple in the video come from?
ranaakamarth (author) in reply to JamesRPatrickJul 8, 2007. 3:39 PM
thanks lol.... it was an example that i drew in abut 2 minutes.. i can actually draw way better... The purple was a substitution to red... I have 3 sisters so we have ALOT of fingernail polish laying around our house. I was having trouble with stickers so I just simply painted my cube with fingernail polish (no red). I strongly suggest using fingernail polish. It stays on great if you can get some high quality stuff and not the stuff from dollar general. I havent repainted my cube for a year or so or something like that. By then with stickers i'de have had about 20 resticks
HitmanSA says: May 4, 2009. 6:03 AM
forget all i said i just solved my cube thanks a lot man you are my hero thnx
HitmanSA says: May 3, 2009. 2:28 PM
please explain i don't understand this Note: the back turn is turning it as if you are holding the back side as the front. That does not mean that you solve it with the back on the front though. I might upload a video of what I mean.
HitmanSA says: May 3, 2009. 2:19 PM
omg i do it there is no --- made to the top why?
HitmanSA says: May 3, 2009. 2:17 PM
omg i do exactly what it says but i can't get a cross to the other side.i've done it like thousands of times.
HitmanSA says: May 3, 2009. 7:50 AM
oh i forgot to mention the example 2 i mean is on step 2.thank you.
HitmanSA says: May 3, 2009. 7:42 AM
what dustin_virva says is very logical.When i see your videos i can't understand anything because it's too fast and when I look at the pictures of the examples i don't understand what i'm trying to accommplish e.g.Example 2.Ok please explain what i will accomplish by doing what example 2 says.A video with slow movements for each example would surely stop confusions for a lot of people.
bertj says: Apr 14, 2009. 3:55 AM
this is a very helpfull instructable,
was looking for it a long time
many thx
but an advice,
highlight that last sentence (referring to the back turning)
I did not read it until i failed like 4 times doing this step!!!!
I almost ate my cube!! ;)
grtz
ranaakamarth (author) in reply to bertjApr 14, 2009. 12:41 PM
Thanks. I can't remember how I wrote it to turn, but I'll make sure to make it more noticeable. (How do you highlight stuff?)
ranaakamarth (author) in reply to ranaakamarthApr 14, 2009. 12:45 PM
I put it in bold. Maybe that will make it clearer.
bertj in reply to ranaakamarthApr 15, 2009. 3:12 AM
thank you very much
it'll save people a lot of nerves :)
grtz
ranaakamarth (author) in reply to bertjApr 15, 2009. 6:12 PM
Yw. You posted your comment at the perfect time. If you had told me to highlight it earlier then I probably wouldn't have gotten around to it. I just started solving again after almost 8 months of not speed cubing. lol My cube was way to loose and I had no glue to fix the caps if I were to take them off. I may add a section about DYI cubes and what types of glues to use, because some glues don't work strong enough and others melt the plastic together.... wow I ramble...
DELETED_trevyboy says: Apr 12, 2009. 8:20 PM
(removed by author or community request)
ranaakamarth (author) in reply to DELETED_trevyboyApr 15, 2009. 6:08 PM
Do you mean without using a method for every time? That is nearly impossible. You would have to be a true genius to solve it intentionally without using any type of method. But if you mean tell me the state of your cube, and I tell you the exact moves to solve that state for you so you can fix it. Then I might be able to do that.
peezzee says: Feb 21, 2009. 12:01 PM
okay so ya i think your move from the movie and your move thats listed on the page are different........
ranaakamarth (author) in reply to peezzeeApr 14, 2009. 12:46 PM
Oops. I changed the text but not the video.... I think i'll do that later some time.
mega man 4bm says: Feb 20, 2009. 4:28 PM
Oh nice rs music in background lol. I play too fyi.
alongsan says: Feb 5, 2009. 8:58 AM
well, thanks...i never imagine that i can finish this puzzle.. now i just have to improve my time..thanks again. nice tutorial..
mega man 4bm says: Feb 1, 2009. 11:01 AM
Lol to solve on a video just video tape you scrambling it up then play backwards!!!
ranaakamarth (author) in reply to mega man 4bmFeb 1, 2009. 2:27 PM
That would be a possibility. but you can see that i'm doing something in the video.
tudgeanator says: Jan 16, 2009. 11:38 AM
sooooooooooooooooo confused...
jaymeb says: Jan 4, 2009. 12:01 AM
What do you do when two of your middle layer edge pieces are already in the middle, but on the opposite side from where they're supposed to be?
ranaakamarth (author) in reply to jaymebJan 4, 2009. 5:25 PM
Its been so long since I've solved a cube, but... From how you are explaining it I would do either the left or right move on this page and take the misplaced cubie out, and then put that cubie into its correct place using one of the moves. Then do the same thing with the other one.
jaymeb says: Jan 4, 2009. 1:48 PM
Thank you so much! I just solved my first rubik's cube. You're tutorial was super helpful.
1-40 of 121Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
