3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Solve "The Cube" + Tips and Tricks For the Rubik's Cube
Step 12Applying the Lube
Applying the Lube
Next we have to apply the lube. This part is very easy. First turn the top 45 degrees (It doesn't have to be exact). Next stick your thumb or a butter knife under the edge piece and lift up. You should be able to pull out the piece. After you take out the edge piece take the cap off the syringe and place your palm on the pump and middle finger and pointer finger on holds then slowly push until some silicone lube comes out. You do not need a lot of silicone, if you put to much on it wont dry up and will leak out when turning the cube. After you place a small amount of silicone on the cube place the edge piece back on. After you place the piece back on randomly turn to cube to work in the silicone. You should see an instant increase in your turning speed. Watch the video if you do not understand.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ranaakamarth
