Step 13A few "Pretty Patterns"
First Pattern "Circle around dot."
In this pattern it may look like the centerpieces are changing around the edges and corners. Since centerpieces don't change position relative to each other it's just the edges and corners moving around the centerpieces.
(Picture one)
Move
Middle: Up
Middle: Left
Middle: Down
Middle: Right
Second Pattern "X marks the spot."
This takes all the edge pieces and swaps them with the ones opposite their original position. To make that easier to understand say you have a cubie in the Front Left position. It swaps it with the cubie in the back right position. And the cubie in the Top back position swapped with the bottom from position.
(Second picture)
Move
Middle: Up 2 Times
Middle:Left 2 Times
Middle:Clockwise 2 Times
Third Pattern "I C you."
This pattern basically takes the cubies on the bottom layer and swaps them across the side. So the cubie on Bottom Front swaps with bottom back and Bottom left swaps with bottom right. It makes 4 c's if you turn the cube on the side.
(See third image)
Move
Right: Up
Left: Down
Top: 2 Times
Right: Down
Left: Up
(Turn the cube 1 time clockwise so the side that was on the left is on the front)
Right: Up
Left: Down
Top: 2 Times
Right: Down
Left: Up
Fourth Pattern "I, I Captain"
In this pattern It is basically the same as "I C you" Except it swaps the cubies on the top layer AND bottom layer in the same way. It looks like alot of I's if you turn the cube on its side.
(See fourth image)
Move
Left Up 2x
Bottom Right 2x
Left Up 2x
Bottom Right 2x
Left Up 2x
Right Up 2x
Top Right 2x
Right Up 2x
Top Right 2x
Right Up 2x
Top Right 2x
Left Up 2x
comments
Add Comment
Add Comment
