Step 9Orienting the Last Layer Corners
In this step we will be twisting the corners to solve the cube. First before you do the move you must turn the cube so the white is on the right and yellow is on the left. (Last layer on left. First layer on right.) Then rotate the cube so an unsolved cubie is in the top left front position. (Remember keep white on right while you do this.) When you do this move you must repeat it either two or four times. To tell how many times you need to do the move. Do the move that was in the top left front position has the yellow sticker facing the yellow side (correctly oriented) WARNING!! THE REST OF THE CUBE WILL BE SCRAMBLED!! THIS IS OK!!! Once the piece is twisted correctly turn the left side until another unoriented piece from the last layer is in the top left front position. Then do the move again. Repeat this process until the cube is solved.
Move
Right: Up
Top: Counter Clockwise
Right: Down
Top: Clockwise
(2 times or 4 times)
Congratulations!!! Cube Solved!!!
I'm adding a new video soon!
now i now how to solve rubic's
thanks alot.......
( * ) he he he he
