Introduction: How to Solve a Rubiks Cube
Picture of How to Solve a Rubiks Cube
This six step intructable will take you through everything you need to know when it comes to solving the Rubik’s Cube. It is really simple, you just have to follow the steps and you will be solving the Rubik’s Cube in less than two minutes (yes, that quickly!). This guide on how to do the Rubik’s Cube will take about 45 minutes to learn, but once you have you can impress all your friends with how you can solve one of life’s great mysteries: how to do a Rubik’s Cube.
Step 1: GET TO KNOW YOUR RUBIK’S CUBE
Picture of GET TO KNOW YOUR RUBIK’S CUBE
THE PARTS:
EDGE PIECES
Pieces with two colors. There are twelve edge pieces located in the middle rows . .
CORNER PIECES
Pieces with three colors. There are eight corner pieces located on the corners. . .
CENTER PIECES
Pieces with once color. There are six center pieces located in the center of each side, center pieces DO NOT MOVE and represent the color of their side. Center piece colors are always opposite each other.
EACH SIDE OF THE CUBE IS REPRESENTED BY A LETTER
R = Right face - Right side of the cube
L = Left face - Left side of the cube
U = Up face - Top side of the cube
D = Down face - Bottom side of the cube
F = Front face - front side of the cube
B = Back face - Back side of the cube
The letter with an “i” after it means an inverted or counter-clockwise move when looking at that face directly
VERY IMPORTANT
When making the moves above hold your Rubik’s Cube full-face front with the logo on top as shown. Dark grey on the pictures means that the color does not matter. Each move is a 1/4 turn rotation.
Step 2: SOLVE THE WHITE CROSS
Picture of SOLVE THE WHITE CROSS
HOLDING YOUR CUBE
Holding your Rubik’s Cube with the white center piece on the top face, you must create a white cross as shown. Much of this level is achieved with practice and by trial and error… but we do have some tips.
TIPS
Be sure to solve the sections of the white cross in the following order - blue, orange, green, red. - Notice the EDGE PIECE COLORS above match the top white center piece and the side red and blue center pieces. This is how we know the edge pieces are in the correct positions. - Keeping the white center piece on top, move the blue/white edge piece to the bottom face, then rotate it on the bottom until it is directly under the blue center piece. Now hold your Rubik’s Cube so the blue center piece and blue/white edge piece are on the right face. Rotate the right face until the blue/white edge piece is on the top face and above the blue center piece.
- If your Rubik’s Cube looks like this, hold your Cube so the orange center piece is on the right face and start solving the side with the orange center piece the same way as stated above. - If your Rubik’s Cube looks like this, do the sequence below making sure the blue center piece is on the right face.
CONGRATULATIONS!
If your Rubik’s Cube has a white cross that looks like this picture, you can move to Step 3
Step 3: SOLVE THE WHITE CORNERS
Picture of SOLVE THE WHITE CORNERS
HOLDING YOUR CUBE:
With the white cross in the top face, you must solve the white corner pieces. As in this picture. .
TIPS:
Corner pieces will have one white side plus 2 other colors. if the corner piece is already on the bottom face, then rotate the bottom until the corner is directly below its intended location. Once in that position, your Rubik’s Cube may look like any one of the three pictures on the right. THEN do the sequence below 1X, 2X or 3X or UNITIL it is in the correct position.
Repeat this process for all four corners. If the corner is on the top face of the Cube, move it to the bottom face by doing:
CONGRATULATIONS!
If your white layer of your Cube looks like the picture here, you have completed one third of the Rubik’s Cube and you can now move to step 4! . . . .
Step 4: SOLVE THE MIDDLE LAYER
Picture of SOLVE THE MIDDLE LAYER
HOLDING YOUR CUBE:
With the COMPLETED WHITE LAYER on the BOTTOM, now you have to solve the middle layer, which means positioning the ‘edge pieces’ in the correct place. .
TIPS:
Notice the vertical row of blue(this could be red, orange, green) - THIS IS CRITICAL!
Create a vertical line by rotating the top face until the front color of the edge piece on the top face without yellow on it matches a side center piece. The color on the edge piece’s top face will determine the direction the edge piece should move.
- Create a vertical line by rotating the top face until the front color of the edge piece on the top face without yellow on it matches a side center piece. The color on the edge piece’s top face will determine the direction the edge piece should move.
1) If you’re moving the edge piece in the same direction as indicated in the picture, then follow the sequence of moves pictures above(picture that starts with U)
2) If you’re moving the edge piece in the same direction as indicated in the picture, then follow the sequence of moves pictured above(picture that starts with Ui)
Continue these steps until all the edge pieces are in the correct position.NOTE: If one of the edge pieces is already in the middle row, but in the wrong position, then do either one of the sequential moves and it will move to the top layer. Then you can do the appropriate sequential moves to position it in the correct location of the middle layer.
CONGRATULATIONS!
If your bottom two layers look like this picture, you can move to Step 5. You are two thirds of the way done!
Step 5: SOLVE THE TOP FACE
Picture of SOLVE THE TOP FACE
HOLDING YOUR CUBE:
1) Matching the yellow pattern on the top face of your Rubik’s Cube to one of the yellow patterns shown on the Cubes below. 2) Then follow the correct sequence.
TIPS: Yellow edge pieces on the top face do NOT need to match on the side pieces…yet!
1st Step: Make a yellow cross
2nd Step: Make all the corners yellow
NOW, look at the top face of the Rubik’s Cube and match your face to one of the states below.
State 1
If no corner Cubes are yellow on the top face, you must have yellow left corner or left face as shown. .
State 2
If one corner Cube is yellow match your top face as shown and do the sequence below. .
State 3
If any two corner Cubes are yellow don’t worry about their position. You MUST match the front face with a yellow left corner as shown . Do this sequence 1, 2 or 3 times to achieve a complete yellow top face. After each sequence, orient the Rubik’s Cube to REMATCH the top face to the appropriate state and repeat the sequence until all the corners are yellow
CONGRATULATIONS!
If your Rubik’s Cube looks like this picture you can move to Step 6!
Step 6: SOLVE THE FINAL LAYER
Picture of SOLVE THE FINAL LAYER
HOLDING THE CUBE:
Hold the Rubik’s Cube as shown, NOW twist the top face until at least 2 corners are in the right location as A, B or A, D or B, C as shown below. If all 4 corners are in the right place you can proceed to the 2nd step.
1st Step: Position yellow corners correctly While holding your Rubik’s Cube as shown above, look at the top face. Place the 2 correct corners in the back A, B or diagonally A, D or B, C across from each other.
If corners A and B are in the right place then to switch C and D, do the sequence above((picture that starts with Ri)
If you need to switch diagonal corners like B and C or D and A, then do the sequence once. Then, orient the Cube so the 2 correct corners are in the back and do the sequence again.
2nd Step: Position yellow edges correctly
If 1 edge is correct and 3 edges are incorrect orient the Rubik’s Cube so the face with the correct edge is the back face. Then determine if the edge pieces need to move clockwise or counter-clockwise and do the correct sequence above. .
If all 4 edges are incorrect, then do either sequence above once, and then determine what direction the three edge pieces need to move and do the correct sequence above. . .
To cycle EFG Clockwise or EFGH Clockwise
CONGRATULATIONS!
you have solve the Rubik’s Cube!
DEEJAY246 (author)2017-08-23
A complete plagiarism of the Rubik's steps which are on their website... You're instructions are poor and hard to follow... Booooo!!!
esmond2361 (author)2017-05-23
easy i can solve it in 5 secounds
AlexM621 (author)2017-02-03
doesent work fake
DIY Hacks and How Tos (author)2016-08-22
Thanks for sharing. I have always wanted to learn how to solve these.
About This Instructable
11,825views
36favorites
License:
More by GregS173:How to Solve a Rubiks Cube
Add instructable to:
