How to Speed Clean Longboard Bearings - With a DIY Cleaning Kit
Published
Introduction: How to Speed Clean Longboard Bearings - With a DIY Cleaning Kit
About: Online Longboards Skateboard store with Quality boards and friendly service. Great selection of completes, decks, trucks and wheels. Pintail longboards, Cruiser boards, Drop Down or Kicktails we have it. Fo...
Once in a while, your Bearings need to be cleaned, so your longboard will keep riding smoothly,
you want to do it efficient and fast. The DIY bearings cleaning kit is the way to go.
It is very easy and quick.
Step 1: What You Need to Clean Your Bearings
Your dirty bearings, your DIY bearings cleaning kit (one of my other Instructable)
and
  • Citrus cleaner
  • Hair Dryer
  • Paper towel
  • Lubricant (sewing machine oil or Oust oil)
Step 2: Remove the Bearings Shields or Seals
Start by removing the bearing shields or seals from the bearings (video) and wipe the dirt and grease off as much as possible. Do not clean the rubber seals with solvent as it might blister the rubber. Just wipe it clean with soapy water.
Step 3: Stack Your Bearings Onto the Bolt
Stack up the bearing by alternating spacers and bearings to the bolt of your cleaning kit. At the end add your wing nut.
Step 4: Add Citrus Cleaner
Fill the bottle about a 1/3 with citrus cleaner. Close your bottle with the bearings inside and give it a really good shake. Let it sit for a few minutes and shake it again. Repeat this a few times.
Note: do not use solvents like petroleum, alcohol, spirits or other dangerous cleaners. This will harm your bearings.
Step 5: Roll Your Bearings on a Paper Towel
When you think it is done, take them out and tap and roll it around a paper towel to get rid of the extra cleaner and dirt.
Step 6: Rinse Your Bearings Under Hot Water
Rinse the bolt with the bearings under hot running water to remove all citrus cleaner. Do not let the water sit! This is very important. Your bearings will rust really quick if you do this.
Step 7: Dry Your Bearings Completely
Dry your bearings completely with a hair dryer. You can first leave them on your bolt and after that you can take them off and dry them further. If it is to hot to hold, you can use thongs to hold the bearing. This makes the job a lot easier.
Step 8: Add Lubricant to Your Bearings
Next step is the lubricant. There are different kinds.
It is best to use thin lubricant like sewing machine oil or Oust metal oil. If you use thick lubricants, it will slow down your bearings quit a bit and you will have less fun.
Add only a few drops to each bearing.
Step 9: Put the Metal Shields or Seals Back Into the Bearings
Put the seals or metal shields back (video) and you are done.
Now you know how to clean bearings with your home made DIY Longboard Bearings Cleaning Kit.
Do you need new bearings, go to http://longboardsusa.com/bearings/
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    3 Comments
    I have a bottle of dettol and it says it cute grease is it safe to use ?
    That is a good question. Personally, I never have used Dettol, so I am not sure what's in it. I looked it up and it looks pretty similar. My guess it is safe to use as it is also safe for your skin. Stay away from products that contains petroleum distillates. If it contains d-limonene you are fine. You can always try it with an old bearing or start with one to test. Hope this helps a little bit.
    This is so neat! I just looked at the 'ible to make the kit and it's extreamly briliant! I'm excited to see more from you in the future.
