How to Speed Up Windows 7
Published
Introduction: How to Speed Up Windows 7
In the following instructable, you will use msconfig to try and speed up your Windows machine.
Step 1: WARNING
Changing settings within msconfig, if done incorrectly, could severely alter your computer. Only use the following steps if you are comfortable using msconfig.
Make a backup of your computer and files in case of problems.
Step 2: Click on the Windows Icon at the Bottom Left.
Step 3: Type "msconfig" With Out Quotes and Hit Enter.
Step 4: A Window Will Pop Up. Switch the Icon From Normal Startup to Selective Startup.
Step 5: Click on the Boot Tab.
Step 6: Switch the Timeout From Default (30 Seconds) to 3 Seconds.
Step 7: Then Click on Advanced Options.
Step 8: Click on the Check Box Beside ‘Number of Processors’ and Make Sure That It Is Checked.
Step 9: Then, From the Drop Down Menu, Make Sure the Highest Possible Number Is Click, Then Hit Ok.
Step 10: Navigate to the Services Tab.
Step 11: Click on the Status Tab, This Will Sort Everything From "Running" to "Stopped."
Step 12: From the Running List, Uncheck Any That Are Not Being Used, Such As in Apple Inc., the Bonjour Service Has Been Unchecked Cause It Is Never Being Used on This Computer.
Step 13: Next, Navigate to the Startup Tab.
Step 14: From There, Uncheck Any That Are Not Being Used Such Has "Updater" From "Ask."
Step 15: Finally, Hit Apply and OK.
Step 16: The Window Above Will Open Up Requiring You the Restart. Go Ahead and Hit Restart and You Should See a Difference in the Speed.
If the window does not pop up, restart your pc anyway.
Step 17: Troubleshooting
If these steps do not help speed up your computer, you should look into purchasing a new computer.
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    Thanks for sharing :)
