If you follow all of these steps carefully there's almost no risk to get hurt. And, if you'll get hurt when splitting logs, I'm not responsible for it.
UPDATE: Please read the comments in the bottom of the page, though these provide information on how to cut wood in a better and safer way.
Remove these ads by
Signing UpStep 1: What you'll need
An AXE - Sharp, not too small, not too heavy.
A LOG - Dry, it's easier if it's quite small. If you got big logs read the part "Splitting big logs"
A STUB - Or something else to put under your log. It should be stable. The good thing with having a stub is that the axe doesn't get hurt if you fail to hit the log.
Optional:
A SLEDGEHAMMER - May be good if the axe is stuck.
SAFETY GOGGLES - Good for the safety.
A FRIEND - Safe
If you got long logs you'll also need:
A SAW - To make shorter parts, like one foot (~30 cm) long.
A SAW BUCK - Or something else to hold the long logs with when you saw them
Visit Our Store »
Go Pro Today »
I just wanted to comment on your tip to use a sledgehammer to beat the axe through. This is a really bad idea!!!
First of all, both the axe and the sledgehammer are tempered steel and they are brittle. You risk getting a VERY sharp shard of steel coming at you, or anyone nearby, in high speed. This shard can penetrate clothes and cuts through skin easily.
Secondly, the eye of the axe(where the handle is fixed) isn't as strong as you would expect and will collapse after some hard hits with the sledgehammer, ruining your axe. The cracks and bends in the axehead might not be obvious at first but even so the axehead can suddenly come off and badly hurt someone .
BR, J
I've added a note in the top of the post that you should read the comments :)
ledsen att jag la in samma kommentarer som du fått tidigare. Jag följde instruktionen och när jag såg det du skrivit om att slå på yxan med en slägga så tyckte jag det var lika bra att varna för det.
På sista sidan fanns inga andra kommentarer så jag missade dem, det var inte meningen att strö salt i såren ;-)
Ha det bra,
Jim
