3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Start Fire with Water!
You probably already know a few ways to do this, but none that beats this method! It will not only make you be able to start a combustion with a drop of water, but it will be the coolest GREEN flame!
For a brief description please watch this video:
Note: Alot of people have mistakenly claimed that I have stolen video and pictures for this Instructable. To clear everything up, I didn't steal anything, I simply posted elsewhere long time ago, and eventually it became popular on the internet. Look in the beginning of the video for the signature.
Step 1Materials
Materials
Before we start, I must warn you. This is obiously NOT a safe experiment you should allow small kids to make, as this will combust with an explosive-like effect with a drop of water, and might not always go off the way you want it to. This mixture is hygroscopic (will soak moisture from air) because off the ammonium nitrate included. So if it is very humid or raining, making this is not a good idea.
Okay, so let's get started!
For this project we will need following items:
- An "Instant cold pack"
- Table salt
- Zinc powder (grey metal powder, can be bought from unitednuclear.com or inoxia.co.uk)
Further you'll need
- A scale, preferably precise to 0.1g
- A mortar and pestle to grind the mixture
237 comments
1-40 of 237next »
Aug 4, 2009. 5:16 PMzoraxbrooks says:
this would help when campin'
Apr 16, 2012. 8:05 PMDustyJK says:
yep
Oct 4, 2011. 4:47 PMtechxpert says:
a better name would be "insta fire just add water"
Sep 30, 2011. 9:20 AMMutantflame says:
Would Aluminium powder work instead of zinc?
If not, would magnesium work?
Mar 2, 2011. 10:26 AMilpug says:
is there any place other than a chemical store that you can get Zinc powder? is it expensive? is it controlled in any way? I want to try this.
Jun 24, 2011. 8:01 AMostomesto says:
An easy way to get zinc powder is to get a metal file, you cant use sandpaper, and file down some US pennies. They have to be 1982 or later or else they wont be zinc. P.S. they will be covered in copper so the zinc will be under all of that
Jun 17, 2011. 10:02 PMnhoja says:
I think calcium carbide is better and safer!!
Mar 21, 2011. 6:59 PMsonofspikerr says:
sink powder? wtf is sink powder? :) just joking. this would be cooler if it was sustained
Jan 11, 2010. 12:49 PMknektek says:
when zinc burns doesnt it produce toxic gas?
Jan 28, 2011. 8:12 AMfirestarter24 says:
This reaction doesn't produce anything considered toxic at these levels.
This is the reaction that is sped up (catalyzed) to cause the heat and fire.
NH4NO3 --> N2O + 2(H2O)
The salt catalyzes the reaction of the ammonium nitrate along with the Zn.
Zn + NH4NO3 --> N2 + 2(H2O) + ZnO
So the only products that could be left if all your starting materials react are zinc oxide, water, nitrogen gas, and/or nitrous oxide (aka: laughing gas). No problem.
Jan 29, 2011. 5:46 AMknektek says:
Fast reply time :L
Jan 31, 2011. 6:37 AMfirestarter24 says:
Eh better late than never. Yet still somehow faster than when I try contacting customer service at some places.
Also, I thought your message said, Jan 11, 2011 when I first read it.
Dec 30, 2010. 3:10 PMsparky57 says:
you can get the potassium permanganate at chemicalstore.com it's used for air and water purification. you might also find it at a self chem store or a pool supply store.
Dec 30, 2010. 3:02 PMsparky57 says:
you can buy glycerin in small bottles, over the counter at the local drug store.
Nov 4, 2010. 7:42 PMA is for Anarchy says:
would it work to use the zinc from the middle of an alkaline battery? i know the zinc powder is mixed with potassium hydroxide, would the KOH interfere at all in the reaction?
Oct 13, 2010. 8:02 PMCodeKid1001 says:
so which is the part that reacts with the water
Jun 3, 2009. 8:04 PMKataze says:
Since ammonium nitrate is acting as an oxidizer here, can it be replaced with KNO3?
Jun 19, 2010. 10:54 PMJamesTB13 says:
if you have KNO3, why not just make gunpowder? All you'd need is sulphur and carbon, and carbon is easy, just use charcoal.
Jun 5, 2009. 9:46 PMKataze says:
ugh, figured as much. Just a bit of wishful thinking on my part.
Jun 5, 2010. 12:25 AMzombiefire says:
will a medichill work
May 18, 2010. 5:39 PMA.C.E. says:
can i use zinc from zinc pills from the drug store? is it pure enough? last time i just grinded down some pennies and it worked (well ignited from humidity) but it took forever and was difficult..
May 10, 2009. 1:32 PMcomputer_guy says:
so you CAN'T use the mixture after being stored?
Jul 8, 2009. 9:51 PMhoihoi151 says:
well if moisture gets into the mixture while its being stored. it could end very messy.
Jul 19, 2009. 11:41 PMcomputer_guy says:
right, right... time to try and make a DIY on Vacuumed sealed bags XD
Apr 16, 2010. 5:37 AMpyrorower says:
Well you could just put it in a plastic bag with some silica gel packets and get as much air out as you can. The silica gel should soak up any moisture, keeping it from having any problems.
Apr 16, 2010. 5:39 AMpyrorower says:
If the ammonium nitrate is just an oxidizer, can it be replaced with potassium nitrate?
Jan 17, 2009. 7:00 PMalexeagle6630 says:
how do you make the fire stop and what is a cold pack alexeagle6630
Aug 26, 2009. 12:41 PMKWeippert says:
If you have no idea what a cold pack is.....you shouldnt be trying this experiment!!!
Jun 28, 2009. 2:17 PMA.C.E. says:
hey it will go out in just about 3 seconds if you follow this guys amounts.
Feb 23, 2009. 4:37 PMcodongolev says:
cold pack- sold at drugstores, used for injuries. you squeeze the pack of water inside and burst it, and the resulting reaction takes more energy than it creates, therefore making it cold. it's useful for sports, where there's no freezer around.
Feb 20, 2009. 9:42 PMJaycub says:
Once you light a mixture that has the oxidiser in it the only way to put it out is to remove the fuel source. So unless you want to poke a stick in it and try to scrape out the un-burnt part of the mixture while it's going you basicaly can't put it out.
Feb 25, 2009. 5:27 PMTFrosty says:
You could put a bucket over it, getting rid of the oxygen. You have to eliminate one part of the fire triangle, source, heat, and oxygen
Feb 25, 2009. 6:03 PMJaycub says:
The amonium nitrate serves as an oxidizer, it doesn't need oxygen from the air.
Feb 25, 2009. 9:21 PMTFrosty says:
My mistake. I completely blanked out on that.
Wow
Jan 19, 2008. 3:58 AMcooldog says:
can you sub the zinc with anything else i'm thinking of using it to start camp fires
Jun 28, 2009. 2:19 PMA.C.E. says:
no, but you can just sand down some pennies and get the zinc thats under the copper.
1-40 of 237next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:pudi.dk
