How to Start a Fire Using Flint
 by mlb1993
What happens when you are out camping in the middle of the woods and you need to start a fire but all of your matches are wet? You don't want to wait around for them to dry because it is getting dark, and they might not even work. What do you do? Well, if you had some flint, your problem would be solved.
Knowing how to start a fire using flint is very useful and can save you a lot of trouble. Unlike matches, flint can be used in almost any situation at almost any time, and you don't have to worry about your flint getting ruined if it gets wet.
Step 1: Materials
Here is what you will need to start a fire using flint:
-Flint
-A pocket knife (Only if your flint does not have a scraping tool)
-Small kindling to get your fire going (Paper, cardboard, dry grass, and small dry twigs all work well)
-Larger fuel to keep your fire going (Sticks and eventually logs, once your fire gets big enough)
Dread_Neck says: Mar 7, 2013. 10:10 PM
I have the same starter! Great instructable. Not to be a snitch but i'm pretty sure it's magnesium shavings, not flint.
unclelar says: May 10, 2012. 3:52 AM
what you are using is a magnesium bar,and the shavings are that of magnesium not flint,otherwise not bad.
mlb1993 (author) in reply to unclelarMay 10, 2012. 4:16 AM
Oh ok, thanks! That's what I was thinking it was, I figured it wasn't flint, but I wasn't totally sure. Thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
