How to Stop Stripping Screw Heads
 by crankyalbatross
Featured
This instructable is a quick modification for drill drivers done at Techshop that will help the drill bit driver to seat into a screw head better so you can avoid stripping out the heads of your screws. The taper (point) on a driver bit sometimes gets in the way of it seating snugly into the flat bottomed screw head. As always start with the correctly sized driver for screw you are using.
Materials/Tools Needed:
Driver
Screw
Cordless Drill
Disc Sander (Techshop!)
Metal File
Step 1: Load Driver Into Cordless Drill
Load the driver bit into your cordless drill.
dll932 says: Sep 23, 2012. 1:23 PM
Sometimes you have to work with what fasteners are already THERE, like fixing an old piece of equipment. I have done the following:
1) slot the screw head with a Dremel and cutoff wheel.
2) Get a product called Screw Medic (basically emery dust in oil - like valve grinding compound). Put a little on the driver tip, gives more traction.
3) Squirt Rem Oil or Pblaster or WD40 on the screw head. Wait a moment. put the driver in the head and tap sharply with a hammer on top of the head. Then, TIGHTEN the screw slightly to break loose and then loosen.
4) Look for "anti-camout" bits from those tool-store-in-a-trucks. These have teeth cut in them so they tend to stay in as you extract the screw.
mickryobe says: Aug 2, 2012. 11:03 PM
To entirely avoid all this trouble why not use Robertson (square head or square recess screws) in the first place?
Check Robertson screws on Google to see their many advantages.
I have a set of three Robertson screw drivers that have been used for over 50 years and still hold the screw securely in any position. The tips show no signs of wear. Phillips screwdrivers self destruct in a relatively short time.
They are ideal for use in power screw drivers or drills. One hand is always free as there is no need to hold the screw.
They have never damaged a screw head.
They are colour coded, red green and black for the original three sizes of head recesses available. There are now other sizes each having its own colour code.
Quanah says: Jul 12, 2012. 5:18 AM
Phillip's head failures led the way towards the invention of square drive and Torx head screws...what an improvement!
kill-a-watt in reply to QuanahJul 12, 2012. 2:48 PM
Well, Phillips screw drive was designed to limit the torque that could be applied by camming out, yet still be able to be installed by automated equipment. This was done because early equipment didn't have any inherent torque limiting features, probably due to expense.
Because it was so successful, it became the de facto standard, even in applications where the cam out feature is undesirable.
shannonlove in reply to kill-a-wattJul 19, 2012. 6:21 AM
Ease of manufacture and not ease of maintenance usually governs screw choices in design. That was doubly true back in the day when factories were almost the only places that had powered drivers. I think it was Henry Ford that first widely adopted the phillips, head precisely because it sped up production so much.
These days, torq limiting in maintenance is almost always signaled by a regular/single-slot screw. Those are heck to put in during manufacture but you really have to work at them to over tighten them.
The days of phillips head are clearly numbered. Despite the cost, I have begun to go out of my way to buy square or torx head screws in my own work simply because they are so much easy to work with and way more reliable to remove. I believe everyone should try the new styles out if they haven't already.
shannonlove says: Jul 8, 2012. 3:38 PM
In the past, I have flattened a bit by simply chucking it in a drill and then running the drill with the bit pressed against a grinding surface e.g. sandpaper, an immobile grind stone, metal file etc.
Since you're only removing a couple of millimeters (1/16") of material you don't really need a one-meter/one-yard in diameter stationary sander. ;-)
If you do find yourself with a stripped screw like the one in the first photo, a square drive bit usually a #2 will actually fit snugly because when the phillips strips out, it leaves a diamond shaped or square hole.
I am ashamed to say I never thought of that until one day I accidentally chucked a square bit while removing a stripped phillips and it came right out. *Sigh* Hate to think how many man hours I blew over the years not realizing that.
tim_n in reply to shannonloveJul 19, 2012. 4:58 AM
damn good point about the square hole! Never even thought about it myself.
lime3D in reply to shannonloveJul 11, 2012. 5:50 AM
The disc sander is standard equipment at TechShop. The author clearly indicated that this was a technique done at TechShop, so using the available equipment makes sense.
shannonlove in reply to lime3DJul 11, 2012. 7:36 AM
I was just being humorous. I was amused at using such a large and powerful tool for such a small task. Of course, if it's the tool sitting right there, then it makes practical sense but the juxtaposition was funny nevertheless.
caarntedd says: Jul 11, 2012. 9:03 PM
Nice tip.
popewill says: Jul 8, 2012. 12:21 PM
Nice Idea! But, I'm not sure if I'd be willing to sacrifice a drillbit for it though... I'll keep this in mind next time I have a stripped screw!
lime3D in reply to popewillJul 11, 2012. 5:53 AM
doo da do in reply to popewillJul 8, 2012. 1:29 PM
Look at the local pawn shop, the sell sockets and probably replacement bits dirt cheap. I have found craftsman sockets for $1.00.
Dr Qui says: Jul 11, 2012. 5:23 AM
You should run the drill/driver when holding it against the sander/grind stone. This will give you a squarer finish with hopeful no need to do any filing at all.
waldosan says: Jul 8, 2012. 4:46 PM
the metal on the tip looks blue, i think you might've messed with the tempering, do you find it harder or softer?
curious youth in reply to waldosanJul 9, 2012. 3:25 AM
mines pretty hard ;)
i dont think that small amount of sanding/grinding/whatver you wish to call it would have affected the tempering
chromebones says: Jul 8, 2012. 9:35 PM
...enjoy frustration free screwing!
That's what she said.
richms says: Jul 8, 2012. 3:51 PM
Best solution is to stop using philips and pozi fasteners. The philips was designed to cam out and the pozi doesnt do much to correct it.
I wont buy fasteners other than square or metric hex drive for my personal use. IMO its a shame that torx didnt get more use on fasteners since its the most superior one.
CaseyCase says: Jul 8, 2012. 2:04 PM
Stop stripping screw heads by throwing out that cordless drill and using an impact driver instead--c'mon, all the cool kids are doing it!
unclelar says: Jul 8, 2012. 12:59 PM
popewill- you aren't sacrificing anything,you are actually improving it.So long as you don't remove to much of the tip.Works great,been doing this for years.FYI it is a driver bit not a drill bit,big difference.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
