Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Pardon my "Automatic Translator English"
Thanks by your suggestions about my English. I use normally http://ets.freetranslation.com/ that is very good.
It sounds like your brakes are too grabby- if you can't get the balance between not braking hard enough and doing a sudden stoppy then they probably need to be a bit more progressive. The V-brakes on my old downhiller could bring it to a controlled stop just before the point of lifting the back wheel (a few car lengths from about 25-30mph going downhill) because they were powerful but progressive.
Of course, on dirt this all changes, because using the front brake hard risks skidding the front wheel which is sometimes worse than going over the bars. In those circumstances I brake the back wheel to the point of skidding and use the front brake carefully while sitting just above the rear wheel to get my weight backwards.
