Introduction: How to Stop a Cat From Spraying
Picture of How to Stop a Cat From Spraying
HERE ARE JUST A FEW THINGS YOU’LL DISCOVER
IN CAT SPRAYING NO MORE How to work out WHY your cat is peeing in the house in the first place (once you know the reasons for why your cat is eliminating outside the litter box, it’s so much easier to stop!)Time-tested and proven ways to ensure your cat uses the litter boxA special HERBAL REPELLENT MIX you can easily make from home that will break the ‘peeing cycle’ and stop your cat from eliminating in unwanted areaspermanently!How to use your cat’s own instincts to stop them from peeing outside the litter boxHow stress can cause your cat to pee in all the wrong places, and how to eradicate the problem FAST!What signs to look for to determine whether your cat’s inappropriate peeing and spraying is a behavioural issue, or requires an urgent trip to the vetThe #1 rule every cat owner MUST follow when setting up a litter box at home3 real-life examples of how I stopped my own problem cat from spraying in the house – and how you can do it too4 completely natural, HERBAL REMEDIES proven to stop cats from peeing in unwanted places (plus a step-by-step guide on how to implement them correctly)1 WEIRD TRICK that will make your cat WANT to pee in the litter box, and nowhere elseHow NOT to deal with a cat peeing problem (this is an incredibly common mistake amongst cat owners, but if you do this, you’ll be setting yourself up for a whole host of new problems!)And much, much more!
About This Instructable
144views
0favorites
License:
More by rakasubagja:How to Stop a Cat From Spraying
Add instructable to:
