This was also a project that kept changing. The initial design worked, but not very well (or for very long.) I kept redesigning as I went along, tweaking the bike for more reliable use. In its current condition it is quite effective at moving someone around and makes for a quick and easy to build project. My initial build lasted about 8 hours over one day. When I hopped on the thing and went flying down the road at speed, I was very thrilled and surprised to have gotten that much of a result out of one day of bodging. While you view this project, please keep in mind that some major improvements could be made to my design to fix various safety and performance issues. If you plan on building a similar design, make sure check out the lessons learned step before you build.
For more info about this project and a bunch of others, check out my website: thewidgetforge.com
Remove these ads by
Signing UpStep 1Design
The design was constrained most by the motors available to me at the time and my lack of welding capabilities. I wanted to use my all-terrain style 12 inch tire scooter along with a clutch but I couldn't come up with the necessary equipment. My searches of local (and on trip that was not so local) yard sales and eBay returned few useful motors. Mounting the motor without welding also posed a challenge since that was the efficient and obvious way to fix everything together.
When I couldn't get a motor with a clutch, I got frustrated enough to haul off and improvise a spindle driven design for my bike from 5th grade. The bike is quite small for me, but still allows pedal starts and has coaster brakes which frees the handle bars for the gas and kill switch. I decided to make it front wheel drive for ease of construction: there's a lot more free room up front.
For the engine, I used a small 26cc McCullough engine which came from a hand-held leaf-blower. It is a half shaft motor (only one side of the crankshaft is supported) without a clutch, but it had a threaded shaft which allowed for easy attachment of the spindle so I was happy.
I initially went very simple with the design: just make some brackets and bolt it on. That worked for a few miles when the engine mounts loosened up and the spindle stopped transferring power. I eventually modified the bike to include a spring tensioning system to keep the motor firmly on the tire.
Anyways, in step 7 he says it will and you can always help it out by pedaling.
Nice instructable Jnkyrdguy! I have been wanting to do this for years now, but my designs always involved attaching something to the spokes and using a belt or chain drive which is more difficult. This seems like a good solution.
