3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Strap a Leaf Blower Engine to a Bike and Go Fast
Step 2Attaching the Spindle
The 1.25 inch spindle with a threaded hole that I used on my bike is a peg which came with my all-terrain scooter. The shaft was already threaded so the spindle was easily tightened onto the shaft and secured with two more nuts. In a spindle driven design, the diameter of the spindle is the only factor that can change the effective gearing of the bike (the tire diameter doesn't matter.) A 1.25 inch spindle works well on this bike as a nice middle ground between top speed and acceleration. It would still be interesting to try out some other sizes.
5 comments
Jul 2, 2011. 9:14 PM1august11 says:
ya, i see that your mount is burnt
Jan 17, 2009. 5:30 PMmarshallmarshall1 says:
The size of the tire does too matter. gears are always a two part system. there is no one gear unless that one gear is just the tire and you're riding a trike. the peg is like the pinion and the tire the spur. if the tire is bigger you're going to need a bigger peg in order for it to go as fast.
Apr 19, 2009. 2:05 AMPrometheus says:
When you are using a roller against the tire, the tire size has absolutely no effect. Here's why: The roller is moving against the outside diameter of the tire. The outside diameter is rolling on the road. The tire is only a buffer between the road and the roller. Whether the tire is 12" in diameter or 120" in diameter, the speed is the same, no matter what. A 20T gear driving a 350T gear driving another 20T gear is still a 1:1 ratio. Remember that the tire is acting on the ground as the final drive, and also that last spur gear, hence any gearing prior to that without an actual reduction is still the same ratio.
Apr 19, 2009. 2:08 AMPrometheus says:
Sorry, but absolutely wrong! You have to remember that this is driving the surface of the tire at it's outside point. If it were driving the wheel by the hub, you would be right, however the wheel in question is merely an idler between the driven roller and the ground. You are mistaking your basis for a mechanical advantage.
Apr 19, 2009. 2:11 AMPrometheus says:
To add, a wheel that was half the diameter turns twice as fast, but travels half as far, hence the tire size you put this roller to is irrelevant to the actual ratio.
Jan 18, 2009. 9:47 AMmarshallmarshall1 says:
I guess i didn't think that out thouroughly. You are correct though. sorry about that.
Feb 7, 2009. 9:32 AMMedways man says:
Hey junkyard...me and my dad are working on the project right now and we have run into the first problem...the peg is too big to thread onto the shaft.
Feb 7, 2009. 9:34 AMMedways man says:
is a very small looking peg but thw hole is too big i guess
Oct 21, 2009. 6:03 AMtomcat955 says:
get a mongose peg
Feb 7, 2009. 11:20 AMMedways man says:
well we just got back from an auto body and they welded it so now we have that on now we just need plywood on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:Jnkyrdguy
