3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Stretch
How to Stretch
I am not a professional, however, I am an athlete. I have been running Cross Country and Track for over five years and have picked up many stretching techniques doing so. In this Instructable I will cover a good bit of the traditional stretches, and some the not so traditional stretches, here it goes...
Step 1Warm-Up
Warm-Up
Before doing any physical activity it is a good idea to warm-up and stretch. Why warm-up? Warming-up helps prevent injury, and gets your body ready to go. By warming-up you begin to stretch, and loosen up many of your muscles. I usually do a half mile jog. Depending on the intensity of the activity you plan on doing your warm-up may be shorter or longer. A good rule of thumb is if you're sweating, you're warmed-up.
41 comments
1-40 of 41next »
Jul 10, 2011. 11:15 PMabaneyone says:
Thanks! This is great advice that I will surely follow!
May 11, 2010. 6:58 AMArana says:
Thank You, this was very helpful. Great instructable!
Feb 27, 2010. 7:18 AMduck_tape_ says:
Its a good idea to do some dynamic stretches before you do static stretches (what you have shown).  Although running helps warm up your muscles it doesn't do it that well, so you can get micro-tears in in your muscles when you do static stretches after only running to warm up.  if you  exercise after this, you can enlarge those tears.  If you are not doing exercise after you stretch, doing just what you said is fine, but if you do some dynamic stretches, they help warm up your muscles much more fully, and greatly reduce the risk of you injuring yourself.
Feb 27, 2010. 1:10 AMEAgle47 says:
I approve of this instructable, I've been doing the exact same ones for a few years now, and I've never had any problem.
Feb 25, 2010. 5:09 PMDarcy777 says:
When I try and open the PDF I get an error.  When I tried again, nothing happens. Anyone else have this problem.  BTW, thank you for this instructable :)
Feb 26, 2010. 3:31 PMcateddy says:
I had the same problem. I found out what the problem was. All the pictures took a long time to come in even with the fast connection that I have. I guess that you will just have to wait and see if it will come in that way. Hope that this helps. Chuck
Nov 14, 2009. 8:30 PMryanpriehl says:
 Funny, I have a brother whose name is Eric too, and he's a runner also. He's gotten lots of leg injuries over the years even though he's faithful about stretching.
Jul 17, 2009. 10:44 AMmichel moltrum says:
great instructable. greetings from argentina, south america.
Jun 6, 2009. 5:57 AMsuzukisuv says:
I agree, great post. Stretching is very good.
Nov 22, 2008. 11:32 AMDannymo says:
Hi Eric, I believe some runners will take exception to this post however if you take the time to read through it perhaps it will lessen your chances of incurring an injury. Starting out a run with static stretches as described and demonstrated by Eric is an outdated thoroughly antiquated method of warming up that can lead to an injury. A dynamic pre-exercise stretch warm up is safer than doing static stretching especially if you are getting ready to do any type of fast, explosive or power type of movement such as running. A static stretch relaxes the joint which predisposes it to injury if suddenly called upon to exert force. Having said I’ll continue with the rest of my comments. Step number two of your series shows a stiff leg toe touch stretch. This is a harsh one that is not good for your lower back and can contribute to back injury not to mention a pulled hamstring. Numbers three, four and five are equally bad stretches due to the muscles being forced to elongate when cold. Photo number six and seven are depictions of a knee injury waiting to happen. These stretches made me cringe; specifically the leg ones where you are placing your knee joint at risk by pulling dangerously off to the side and not straight up as is common practice for this type of stretch. The knee is a hinge joint and is not designed to be pulled off to the side as shown. It can cause damage to the medial and collateral ligaments. My suggestions for all of these (and I wouldn’t be doing any of them) would be incorporate them into the cool down phase after your run when the muscles are warm more amenable to the positive effects of a stretch. A warm up for a recreational runner begins with a slow jog that gradually makes the transition into a faster pace. If however you insist on spending time doing pre-run stretches then do dynamic ones at the get go. Start with gentle short range of motion leg swings fore and aft then side to side. Warm your shoulders up with wide arm swings clock wise followed by counter clock wise movements then start your run at an easy pace until you’re warm up and ready to go faster. Danny M. O’Dell, MA. CSCS*D
Jun 1, 2009. 12:21 PMDannymo says:
Hi Eric, Plyometrics take advantage of stored energy in the ligaments, muscles, tendons, and skin based upon the stretch-shortening cycle. These are for advanced athletes and not for the typical weekend warrior. Unless you are talking about skipping, bounding or other low order plyometric exercises. In answer to your question they would not be my first choice due to exposing the cold muscles and joints to injury. A good warm up consists of an overall body warm up that raises the pulse, breathing and elicits a slight sweat. This transitions into a general area warm up, i.e. upper, mid or lower torso and from there to the movement specific warm up. In the case of the runners this would be a gentle jog until the first requirement is met and then into the run pace. After the run is over do static stretches to the point of mild discomfort-not pain.
May 29, 2009. 12:53 AMMaverchick says:
You really know your stuff. (I am in an undergrad program for exercise science. We're studying strength fitness right now, including static and dynamic stretches.) Everything you've said is dead on to what we're learning.
May 29, 2009. 4:40 AMDannymo says:
The stretching errors identified in the original post are common throughout the industry with uninformed strength and fitness coaches or pseudo-coaches being the worst offenders. It is sad to see a person, especially a young impressionable one, stretching in the manner shown in this instructable. Unfortunately, these stretching myths are difficult to stop due to their overwhelming pervasiveness in our society.
Apr 18, 2009. 10:35 AMgoatgirly says:
I'm in track at school and they have us run a mile, do some calisthenics, and then stretch. I wish we could do a few stretches at the beginning though.
Jun 2, 2009. 4:14 PMgoatgirly says:
I don't know what plyometrics are but, I'm going to the dictionary now.
Jun 2, 2009. 4:18 PMgoatgirly says:
Are you sure it's a word? I just looked in my dad's 20 pound(literally) dictionary and it wasn't there. In fact there was only 5 words that even started with the letters ply.
Jun 2, 2009. 4:13 PMgoatgirly says:
I ran(tracks done for the season at my school) the 200 meter, 55 hurdles, and did shot put. Now I'm in physical therapy for the shot put but, i'm still having fun running around. I'm so glad it's nice and warm out.
Mar 11, 2009. 12:10 PMLadilola says:
I agree with Danny! Even as part of a cool down, the stretch in this photo is putting so much pressure on the knees, and not doing much for the groin, either. A better way would be to bend the right knee when leaning to the right, and drop the head, relaxing the neck. And go VERY slowly! In all forward bending stretches the knees should be kept relaxed, not cocked backwards like in this picture, and image the goal to be to get the chest to the thigh, not the hands to the toes.
Apr 24, 2009. 12:42 AMwikidkaka says:
Very useful instructions.. more so for me.. thanks!! Would try them for next couple of weeks as i have just started a fitness regime for myself..
Apr 18, 2009. 8:22 PMYerboogieman says:
Remember to stretch before and after.
Mar 11, 2009. 12:01 PMLadilola says:
I can appreciate your enthusiasm for physical exercise, but some of these stretches are not very safe because they will put stress on the joints rather than stretch the intended muscle if not done absolutely correctly and slowly! This is true if the person is already fit, but especially if they are just staring out. I think you need to include more instructions for doing the stretches slowly and gently, and to progress from day to day...
Mar 11, 2009. 11:54 AMLadilola says:
Here is a much safer version of this stretch: Stand with both knees bent slightly. Bend one leg and reach with your hand BUT do NOT let the foot touch your butt and do NOT let the knee get in front of your hip. If you do not feel enough of a stretch in the front of your thigh, instead of pulling your leg back or your foot up, keep the knees in line and curl your pervis up and pull on the thigh muscle with your stomach muscles - imagine trying to get your crotch/belly button to your chest in a tight curl. You will feel a deep stretch in the front of your thigh withour risk of knee or groin injury!
Mar 11, 2009. 11:45 AMLadilola says:
It helps to drop the head, too, and lean forward rather than back - it's a lot easier on the neck and reaches lower down the back legs.
Jan 5, 2009. 6:55 PMsta2butler says:
awsum stretches , I am getting back to running and forgot most of these , it was very helpful thank you
Dec 18, 2008. 8:12 AMUdon says:
This is a very good instructable. I've always fannied around when it comes to stretching (bend this way. bend that way. touch feet. scratch ear. hold arm this way. hold it that way. okay I'm done.) I won't forget this guide. Good pics too.
Dec 7, 2008. 6:28 PMchaidrocks says:
That's a good list of stretches. We do about all of these before track everyday. I'm not very flexible though. Are there any exercises that can make you more flexible?
Dec 14, 2008. 1:31 PMchaidrocks says:
Thanks for the advice. I think i'll get one for the holidays.
Oct 27, 2008. 5:18 PMjillg says:
did you enter the burning questions round 6 contest? cuase this is really good.
Oct 26, 2008. 9:13 AMmikeobtuse says:
yay runners, do you two do Isometrics? if so what steps do you do. what are your 5k and 10k times?
Oct 25, 2008. 8:19 PMWeissensteinburg says:
Nice descriptions and pictures. I have a few problems that really come out when i'm running if I don't stretch...particularly my back and shins. Just a few minutes spent stretching before/after exercising really make a huge difference.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Earthy Eric(Candy by the Quarter)
My name is Eric. I like to run, hike, climb, be outside, build stuff, lately design furniture. I don't read a whole lot, however, I do enjoy reading, weird huh? I'm a simple kid, it doesn't take much ...
more »
