3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Strip Wire (Without A Wire Stripper)
This is a method of stripping wire that one of my friends showed me. I noticed that I use wire for a lot of projects and don't have a wire stripper. This way is useful if you don't have a wire stripper and you're either broke or too lazy to get one. It may seem like it takes a while to do, but once you get used to it it barely takes any time at all. This method is similar to the one by Weissensteinburg, but my friend said that this way may be better for the wire (less likely to damage it) but I'm not sure. Feedback is always appreciated!
Remember, If you liked it you could always rate it +1 :)
Step 1Materials
Materials
A utility knife (see pictures)
Your wire
Good lighting
A marker
Scissors*
*Optional (Only needed if your sharp knife can't make it through the wire)
42 comments
1-40 of 42next »
Jan 8, 2012. 9:00 AMsecondplanet says:
Thanks, awesome tips there.
Jan 2, 2012. 4:15 PMMayday001 says:
You gotta love the internet, four years later and the advice here is still useful. I'm a woman, not particularly handy, and I used the burn method to strip my speaker wire. Worked like a charm and I love the sound of my new, clear sounding speakers. Thank you to all above who posted, helping to rid the world of one more set of old static-ey speakers.
Feb 2, 2008. 12:34 PMAar000n3y says:
Interesting way of doing it. But the fastest and easiest way is to just take a lighter to it for a second, let it cool for a second, and strip it off with your fingernails. It works very well.
Feb 4, 2008. 8:30 AMrsk11584 says:
At my workplace I have a candle, I just light the candle, and grab one end of wire, and hold the point from where it needs to be stripped over the candle, its the best method without losing a single string..
May 25, 2009. 4:58 PMguggenheim says:
Wow, really good tip, I'll try that.. Any tip on how to strip those extremely thin mini jack plug cables?
Mar 6, 2009. 4:17 PMmultiplecats says:
Good instructable. I've never tried it with a utility knife, I think I'd probably get too happy and cut through it. I have to go at it in a much smaller way - I tend to prefer using the tiny little Swiss Army knife scissors I'm usually carrying on me. I just take the wire, bend it across the lower shear, then carefully close the beak until just the edge of the wire casing is nicked. Then I turn the wire and repeat until I've got a few nicks in it, at which point the casing can just be manually pulled off. Or, you can use the same tool and simply use the very tip of the scissor beak to nick the casing, and then continue as above. But either way, I can strip a wire in just a few seconds, usually without error.
Feb 5, 2008. 12:19 AMalvincredible says:
lol or you can do what TimAnderson did and pull it off with your teeth ( i think it was him, but i could be wrong)!
Feb 27, 2009. 12:36 PMF-zero says:
hhaha i do this too, i swallowed a bit of wire by accident once xD
Jul 27, 2008. 1:23 PMbenthekahn says:
Its not painful. Maybe of you have bad teeth it is but its pretty easy normally.
Mar 3, 2008. 2:57 PMsplatterpaintballer says:
using my teeth has always been easyest for me
Jul 27, 2008. 1:22 PMbenthekahn says:
Same
Jul 25, 2008. 9:34 AMbikerbob2005 says:
should not use teeth the plastic? insulation has lead in it (yikes)
http://www.cdc.gov/mmwr/preview/mmwrhtml/00020984.htm
yes enough to be a bad thing
Jul 17, 2008. 6:38 PMvitruvian8807 says:
Hmm, I just use my finger nails, they are usually sharp enough to draw blood, cut plastic when I slice it, and strip wire when I need it, except when the wire is really small. I'm a guy, so I keep them clean when I let them grow, they come in useful too when you're doing soldering, and I'm also somewhat of a photographer, so I can usually get away with long finger nails. : ) :P
Jul 14, 2008. 4:01 AMPlasmana says:
LOL! My dad uses his teeth to strip wires!
Feb 2, 2008. 1:14 PMmarc92 says:
I have yet to find a pair of decent wire strippers (or I'm not willing to pay for a good pair) therefore I use my teeth to strip wires. It is very convenient because you always bring your teeth with you, (for now.)
Jun 3, 2008. 9:50 PMpappyld04 says:
There is a great pair on the market now. Look like a pair of pliers on one part and strippers on the other. Wire is gripped by one side and stripped by the other. Mine are blue handled and look like a pair of pliers with some MacGyverism done to it. Don't get the thick flimsy handled ones where you put wire in the front and it should bite down then wtrip. These last almost long enough to get to the important part of the job then start screwing up badly. They are JUNK!
Feb 2, 2008. 1:20 PMgmoon says:
I've had a notch in one front tooth for years from biting a bit too hard while stripping wire (I still do it occasionally anyway...)
Feb 2, 2008. 2:41 PMmarc92 says:
Oh, wow. I try not to bite too hard and when I notice that I am I usually stop.
Feb 2, 2008. 1:16 PMgarrettmikesmith says:
that's exactly what i was thinking
May 26, 2008. 11:01 PMhrmcguire1976 says:
use a lighter to heat the plastic and wait for it to hit the melting point and blow out flame. use pliers or something to grab off hot plastic and presto...clean non crimped wire.
Jun 3, 2008. 9:43 PMpappyld04 says:
My friends and I all use this burn method but we just pinch the unwanted with a thumb and forefinger and pull. We are all used to this but I would advise others to wait a minute or so until it cools off. Melted plastic does not make a nice feeling.
Mar 14, 2008. 5:42 PMnightninja87 says:
my mother taught me when i was younger to use nail clippers its a little tricky cause if you push too hard you'll cut the wire takes some practice works easily for me great instructions
Feb 29, 2008. 2:06 PMXellers says:
I just use scissors.
Feb 2, 2008. 1:13 PMGorillazMiko says:
My dad does this all the time, good Instructable, thanks for showing!
Feb 3, 2008. 9:54 AMGorillazMiko says:
+1 rating, WAH-KAH-CHA!!!!!!
Feb 3, 2008. 11:34 AMGorillazMiko says:
Did somebody -1 this Instructable? Because it says rating 0, and I already +1 it.
Feb 2, 2008. 10:58 PMkillerjackalope says:
If you have a pair of scissor, like nail scissors or something elas really sharp you can do the same trick faster by really lightly squeezing the scissors and turning the wire in the blades a couple of times, get your thumbnail in the grooze and slide the casing off, same trick different tool I guess... Yours is likely to be more accurate because it's easy to move the wire when turning.
Feb 3, 2008. 1:05 AMFrenchCrawler says:
I use scissors too. Probably one of the best ways (as long as you don't cut too deep :) )
Feb 2, 2008. 6:58 PMpingeee says:
You can also use the soldering iron to melt the outer plastic, it will be much faster.
Feb 2, 2008. 1:44 PMKiteman says:
I know it's bad knife practice, but I just trap the wire 'twixt blade and thumb, then pull the wire.
Feb 2, 2008. 6:39 PMs666666666666 says:
I'm with stupid. ha I just roll it with my finger like kiteman. I try to stay away from the teeth though. If you're doing it LOTS with your teeth, I figure a $50 pair of strippers is cheaper then a dental bill
Feb 4, 2008. 6:01 AMPKM says:
The word "betwixt" actually appeared on an A-level physics mark scheme- it was a question about a spring sliding on a rod and the phrase they were looking for was "friction betwixt rod and spring". I guess "between" is grammatically inaccurate here. Go figure.
Feb 2, 2008. 12:21 PMLinuxH4x0r says:
I do this all the time. BTW its not an x-acto it a utility knife or box cutter
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:Gjdj3
Music, chemistry, electronics, etc.
