How to Sweat Copper Pipe - DIY Guy
1,386
18
Published
Introduction: How to Sweat Copper Pipe - DIY Guy
About: We build stuff, test stuff, teach you stuff, (and sometimes break stuff). Check us out for new episodes every Wednesday morning on YouTube.
Sweating (or soldering) copper pipe isn't as difficult as you might think. It just takes the right tools and a little know-how.
Step 1: Watch the Video
It's less than two minutes long, no sweat.
See what I did there? Of course you do.
Step 2: Gather Your Materials
Step 3: Sand the Pipe
Use some of the open mesh cloth to sand the cut ends of the pipe.
Copper oxidizes naturally, so make sure to sand down to bright, shiny copper.
Wipe the copper with a clean towel to remove any excess debris.
Step 4: Sand the Fittings Too
You'll also want to sand the inside of the fitting. That's what's going to make contact with the pipe.
Step 5: Time to Flux
Apply a thin layer of flux to the outside of the pipe, and the inside of the fitting.
Flux reacts with the copper and heat and helps ensure you have a clean solder joint.
Step 6: Assemble the Joint
Go ahead and put the pieces together.
If you have more than one joint to make, you should probably avoid trying to do them all at once. Plan ahead and take them one at a time.
Start with your lowest joint, because heat rises. Your later joints will take less time to heat up.
Step 7: Heat and Solder
The idea with this kind of soldering is to apply heat to the joint, not the pipe. And definitely not the solder.
That way, when you apply the solder, the heat inside the joint will suck the solder in. Science!
That's really all there is to it.
Heat + Solder + Capillary Action = Molten Metal sealing a joint.
Step 8: Wipe the Joint Down
Let the joint cool off enough for the solder to set up. This doesn't take long.
Get a (damp) wet rag and carefully wipe down the joint.
You'll get a bit of steam as the joint cools, and that's pretty neat looking, but this is really to remove excess flux from the joint. Flux left on the pipe is what causes oxidation years down the road.
And if that happens, you're back where you started, with a leaky pipe.
That's it, you're done! Move on to the next joint and repeat.
Step 9: Subscribe to Our New DIY Guy YouTube Channel
If you found this Instructable helpful, we'd love it if you subscribed here, as well as over at our new DIY Guy YouTube Channel.
Link to DIY Guy on YouTube
We'll release new episodes every Wednesday morning, as well as extra stuff throughout the week. And remember to turn on notifications at YouTube so you'll know each time we upload a new video. Thanks again!
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    I think the step to remove the burr on the inside of the pipe is missing. Without de-burring, you will get pinhole leaks in a year or two. source - dad is a plumber.
    And a note . Solder will flow wherever you have applied flux so keep it neat
