3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Sweat Solder a brass/copper pipe and couplings
video How to Sweat Solder a brass/copper pipe and couplings
Sometimes you just have to fix plumbing yourself. I recommend that you always hire a licensed plumber for all jobs, but if you want to learn how to solder copper tubing, for projects, in the home, or for repair, here is how you do it
8 comments
Jul 25, 2010. 8:39 PMairsofter1 says:
(removed by author or community request)
Jul 26, 2010. 12:57 PMairsofter1 says:
I am sorry if my comment offended you, I was just saying something. This is a good instructable and it did help me.
Oct 7, 2008. 9:07 AMgloflyer says:
I am not quite sure why you put this up. The title says brass, and you used copper. There are already fairly good instructables here on sweating copper.
May 8, 2010. 11:34 AMonrust says:
I think he is spreading the use of the video link  for advertisement $$.
Oct 10, 2008. 8:18 AMdragonvpm says:
You forgot to mention cleaning the pipe and inside of the fitting (with emory cloth, sandpaper, cleaning tool) before you try soldering. That's an important step for any soldering job you do and it's a good habit to get into even with relatively new (i.e. shiny) pipe (and it's critical if you're soldering older pipe like you might find in a house.
If you don't do this, there's a fairly high probability that the soldered joint can fail due to contaminants (dirt, grime, corrosion, etc..) on the pipe or the fitting. Even new pipe and fittings can have come into contact with something that will adversely affect the solder's ability to bond to the metals.
Also, soldering paste is often referred to as flux (just a useful point in case someone comes across the term in regards to soldering).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:bmerritt5(bradmerritt.com)
