Step 4We don't need flat palms here.
First the hands. Make sure all of your fingers are tight together, and your thumb is pressed against the side of your hand. Curve your hand slightly, as though you were holding a hand full of marbles or a small amount of water. This will help to create more pull when you are going through the water.
Pro Tip: When you take a stroke, keep your hand like it is in the picture, except there should be a slight space between the fingers. It requires more concentration, but you'll get a better pull.\
PRO Pro Tip: Once you feel comfortable enough with your stroke, you can straighten your hand, move your thumb away from your palm and relax your fingers. Unless you want to swim like the flappers.
comments
Add Comment
sokamiwohali
says:
Add Comment
