Why?
As the back light bulb ages, it requires more current to stay on and start. Eventually, this current requirement will exceed the inverter's (a high voltage power supply) capability. This can lead to inverter damage (read: expensive).Symptoms
For about a month or so, my back light starts off as red on startup and slowly returns to normal (white). This can take as much as 30 seconds to a minute. Much recently, my backlight has been turning off randomly, but the frequency has been slowly increasing. As of yesterday - I noticed a high pitched hum sound just before the light kicked off. My light would come on instantly if I hit the screen position switch. And lastly, if I turned the brightness down, most of the symptoms disappears - except the back light had a red tinge to it.Solution
1. Replace Bulb -- this is a $12 partIf problem persists:
2. Replace inverter -- a $70 part, however the bulb should always be replaced when the inverter is replaced.
Remove these ads by
Signing UpStep 1Cautions
Warning
The following procedure will, without a doubt, violate any warranty you have. But who has to know? Take it apart and reassemble properly, and you won't notice :DHigh Voltage
Your back light uses high voltage and sensitive electronics. So please, take care as not to damage these rather expensive components. Static build up will damage these components.
Caution
LCD's are surprisingly flexible given their material. But, they are fragile and should be treated with great care. Never pull on any cords and always allow the screen to rest on a firm, non abrasive, surface.
Reassembly Warning
Please understand, if you are not comfortable working with these components, do not take them apart. You may risk not being able to reassemble properly resulting in a back light that lights, but does not illuminate the screen, or partially illuminates your screen.That's All, You Have been Warned
Thank you Instructables!!
A few comments on this subject imply that some soldering may be required when installing the replacement laptop backlight . Is this really necessary, or just a precaution?
Thanks,
David
You had stated that step 8was Coming Soon!
(Receiving your new bulb - installing and putting everything back together! )
I've replaced the inverter (thanks for the Instructable), but now find that the backlight needs replacing. I've ordered it, but it would be nice to have the Laptop backlight replacement Instructable handy when the bulb arrives.
Can you tell me if it will be on the Instructables site soon?
Thanks,
David
Cheers!
It was recommended. Given the life expectancy of a bulb versus inverter (barring any drops etc. as mentioned), why go through the trouble of having to take the thing apart again and risk damaging the electronics in the screen (causing the "white screen" or lines after reassembly. Then you have to buy a $80-$200 LCD when a $10 replacement bulb could have taken care of that :)
That's especially the case when the inverter fails as a result of the bulb. The reason for the red tint on startup is low current - trying to pull more than the inverter will offer. Older bulbs require more current to run. In my case, it wasn't until the screen started completely going out did I think there was something wrong with the back light (originally, I had thought it was the video card). Most people don't realize this problem until there's more of a catastrophic failure...
On the other side of things, I'll bet only a handful of people actually have a test bulb to check the inverter. The rest of us would need to actually buy a bulb and solder on the old connector to test. I have tried to get dead components from repair shops in the past - and never have any luck :/
Out of curiosity - how much would it cost to have someone like yourself replace a bulb (or would it be model specific)?
