Step 3Snaps aplenty... And The Cursed Glue!
Open up your screen as far as it will go. I did this step with the laptop sitting in my lap. Look at the screen hinge - the portion that moves. There should be two, 8 centimeter sections on the left and right. Inside those movable section, there are two snaps each. these snaps are located about 2cm from the left and right sides of that movable section.
Now, using a jeweler's flat screwdriver as a pry bar, gently and carefully pry up on the snaps.
Once you've released these four snaps, begin to pull up on the bezel using pressure from your finger. You can also use the screw driver for a little extra leverage. As soon as you can, take a peek inside the screen and look for signs of glue tape. It appears that a metal strip covered in glue attaches the screen and bezel together. So move slowly. It is helpful to use a screwdriver to depress on the metal glue band to keep a concentrated pressure point from forming on the screen.
Work all the way around the screen. When you get to the latch, open the latch and continue prying. Then, remove the bezel completely.
Add Comment
