3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Take Apart a Laptop
Step 6Removing the Edging (Partially)
I'm not quite sure what the official name is, so I'm calling it edging. It is the metal band that surrounds the perimeter of the screen.
The back light bulb is located at the bottom of the screen. To remove it, we need to gain access to the bottom portion of the screen - this involves partially removing the edging - removing a supoort bracket and then removing the back light reflector assembly.
First, remove the bottom support bracket. It should be held on with two chrome screws (beware - tiny).
Next remove the support bracket screws (2) - these are chrome. Label and set aside.
Now, remove edging screws (4). These are brass in color. I'm fairly sure you don't need to remove all of them, but you must remove the ones near the bottom portion of the screen.
The edging is held on with snaps around the perimeter and a bit of tape. Remove any tape in the way. You need to carefully insert your screwdriver into these snaps and pry them free. Pry all of the snaps on the bottom and the top two snaps on either side.
Now the edging should pull away from the screen (only slightly). With the edging pulled back, grasp the metal support on the bottom of the screen (this part has holes along the length of it). Rotate it around the screen (to unlock) and then pull away. This exposes the back light reflector.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
324
Author:trebuchet03
I'm an Engineer in San Francisco. Mass producer. Former Intern. Rapid Prototyper. Sometimes, I post Instructables. My Favorite number: 42 By profession - I am an energy engineer. I count electrons p...
more »
