Step 7Remove Backlight
Now, pull the reflector assembly straight out while lifting the plastic carrier away. Be gentle as the back light is in fact a tiny fluorescent tube - and contains mercury vapor.
The reflector assembly is attached to the transflective glass sheet. So, to remove you need to pull it off of this glass sheet which is what will cause most of the resistance.
Once removed, measure your bulb and order a replacement. Make sure your bulb will fit before ordering. I ordered my bulb from lcdparts.net
Thank you Instructables!!
