How to Take Apart a Non-Alkaline Battery
Published
Introduction: How to Take Apart a Non-Alkaline Battery
A Non-alkaline battery is a source of zinc and carbon rods.
I hope you enjoy this instructable and please vote for me in the Explore Science Contest.
Please be sure to use only non-alkaline batteries.
Step 1: List of Materials
You will need:
needle-nose pliers
non-alkaline battery
paper towels
gloves
Step 2: Remove the Plastic Cover
Use needle-nose pliers to remove the plastic cover on the battery.
Step 3: Take Off the Zinc Layer
Use needle-nose pliers to undo the crimped zinc at the postive end of the battery. Then peel the zinc layer off.
Step 4: Remove the Carbon Rod
Using needle-nose pliers, pull the carbon rod out of the encasement. Be steady or the carbon rod will break.
Step 5: Remove the Top From the Carbon Rod
Holding the carbon rod with a paper towel, use the needle-nose pliers to pull the top from the rod.
Step 6: Storage
Make sure to wrap the carbon rod in a paper towel to prevent a mess.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    9 Comments
    Sorry to be a bit dense but what would you want to do this for? Do you have a project for the zinc or carbon?
    Zinc can be used as Sauter I needed some Sauter and zinc is lead free
    Do you mean solder? That is a very good trick. How do you prepare it for use?
    Do you use the carbon rods for something?
    solar world (author) Reply
    I recommend applying flux first but I don't think you'd have to
    The carbon rods work pretty good for electrodes in carbon arc lamps, or for various electrolysis techniques. The zinc can be used for diy galvanization, alloying your own brasses and bronzes, decorative castings (much like pewter), and as a direct replacement for anything that used to call for lead like fishing lures and weights, fly wheels, wheel balance weights, and shitgun shot.
