The Cat 5 standard has been updated to the Cat 5e standard. However, the crimping configuration remains the same, so these instructions will work for either standard.
Remove these ads by
Signing UpStep 1Materials
~ Cat 5 cable
~ 8P8C (8 pin 8 contact) connectors - (these are commonly referred to as "RJ45" connectors)
~ A modular connector crimping tool
~ Wire cutters/strippers (may not be needed depending on crimping tool)
I would say that I would strip a lot more off the jacket (2"). Then trim the wires to the correct length with wire snips or scissors after you have straightened them out and put them in the right order. that way it is a lot less fiddly and you get all the cables exactly the same length. Sometimes if you have a cables slightly shorter than the others it slightly misses the pin as it is crimped. Like the Green and brown wires in the photo above.
That is the way I have been taught anyway :-)
Once all eight are done, and while still pinching the end of the cable jacket, order all the wires as they're intended to lay once the connector is crimped. As cwosley has said in a prior comment, once all the eight wires are laid out in the proper order is the time to cut them to length, which you'd do with the blade-and-anvil of the crimping tool.
At this point, as you visually scan across the row of wires you've prepared and have pinched between your thumb and finger, they should alternate between solid-coloured and striped (this is a general description, applicable to either scheme used, A or B). In other words, you shouldn't see two solid-coloured wires adjacent to each other, nor two striped wires. A more through-going sanity check is to ensure that you've arranged the wires in the proper order as described in this instructable.
Immediately after the above checks, insert all eight wires simultaneously into the connector, and with some force. At this point, you can take out some insurance against a missed wire by looking at the connector end-on: you should see eight bright copper wire ends, all lined up, and all at about the same depth behind the (typically) transparent material of the connector itself. Once you've verified that all eight wires are fully inserted (all come to end 'just behind the glass'), and that the cable jacket (or sheath) protrudes into the connector beyond the crimp wedge, complete the job with the crimping tool.
If you're planning on making several of these, it helps to have a cable ring tool, which basically works like a small razor blade to cut the insulation around the cable. They're cheap and well worth the cost to eliminate the frustration of having cut one of the actual wires' insulation.
They're also known as cable strippers, but that could include coax, so when my then boss objected to my nickname for the thing (not knowing its name, I called it a 'twirly bob', sort of a thingamabob you twirl) I took pains to find out the formal name. : )
i cut 1-1.5 inches of the jacket off then insert the wires one by one... then shove a packet of surgu around it to protect the wire
When choosing a brand of RJ-45 Connectors, i personally use Belkin. they actually have a section in them that gradually gets to the size of the inner wires, and help to keep the inner wires the way you put them before inserting them into the connector. all in all tho, good instructable!
People, it really is this simple. This is a good step by step guide on how to crimp a cable. The rest of the process is just as easy.
