How to Test a Capacitor by Using Multimeter
Published
Introduction: How to Test a Capacitor by Using Multimeter
About: We run YouTube channel and provide some video tutorials on electronics and programming and also videos on cool projects - how to make them, tech news and more. Subscribe to our channel. :)
In this Instructables, I will show you how you can check the working condition of an electrolytic capacitor just by using a multimeter. It is very easy and quite effective as well.
Step 1: Insert the Capacitor in the Breadboard
An electrolytic capacitor has two legs, one is longer and the other is shorter. The longer one is the positive terminal and the shorter one is the negative. Insert the longer leg in the breadboard so that it get the contact with positive terminal of the battery and negative leg with negative terminal of the battery.
Keep it connected for 10 seconds that will charge up the capacitor.
Step 2: Turn on the Multimeter and Set the Range
Remove the battery terminals from the breadboard. Turn on the multimeter and set the range to 20V DC. Touch the probes to the cap legs. Positive probe with positive leg and negative probe with negative leg.
Step 3: Check the Reading
Look at the measurement panel to take the voltage reading. The voltage should be decaying with time continuously.
If the voltage decreases with time then the capacitor is in good condition and if not then then the capacitor may not work properly in a circuit.
I hope this helps. :)
Subscribe to our channel for more videos.
Like our Facebook Page.
Follow us on Twitter.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
