3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to: Tie a Figure Eight Knot
The figure-eight knot is a type of knot. It is very important in both sailing and rock climbing as a method of stopping ropes from running out of retaining devices. Unlike the overhand knot, which will bind iron-hard under strain, often requiring the rope to be cut, the figure of eight can be easily untied after even the greatest strain. (Read More)
Step 1What You'll Need
What You\
You will need:
Rope or String
Lighter, match, or tape (optional)
4 comments
Jul 8, 2011. 6:22 AMCooldeal says:
I can't get it. Need more steps in this. So I guess this knot would be tied onto a post or other item so it can be removed easily?
I thought that it's not a knot until it's pulled taught.
Jul 27, 2010. 3:39 PMAndyGadget says:
There's always the 'trick' way to tie this knot too. Fold your arms, pick up the ends of the string and unfold your arms. Behold! A figure of 8 knot.
Mar 24, 2011. 2:10 PMsyco123 says:
That would give an over hand (aka hitch/pretzel) not a fig8. The "trick" way to tie a fig 8 is to make an open loop held between thumb and finger. The rope tail end should be off to the right and the closed part of the loop pointing down. Twist the loop twice. As you finish the second loop your finger tips will be in the loop, reach through grab the tail pull it through. Take about 2 seconds to tie.
Mar 24, 2011. 3:16 PMAndyGadget says:
You're absolutely right - My suggestion only works if you've got extremely flexible arms #;¬)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Tactical_Pyro
