Introduction: How to Tie a Half Windsor Knot Neck Tie
Picture of How to Tie a Half Windsor Knot Neck Tie
The Half Windsor Knot is a specific way to tie your neck tie. There are several different ways to tie your neck tie, but this is a more common style
Step 1: Materials
Picture of Materials
The materials necessary to make the Half Windsor Knot is simple
  1. Neck Tie
  2. Two hands
The neck tie is customarily wore in collaboration with a collard shirt, but for the purpose of the instructable, I will only be showing how to tie the tie
Step 2: Starting Your Tie
Picture of Starting Your Tie
To start your tie, place the tie around your neck. It is important that the broad end of the tie hangs lower than the narrower end of the tie. This is important so that when the tie is tied the length of the tie comes out correctly
Step 3: Crossing Your Tie
Picture of Crossing Your Tie
The next step of tying the half windsor tie, is to cross your tie. To cross your tie, you will take the broad end of your tie, and cross it over the top of the narrow end of the tie. Then, you will pinch where the two sides of the tie intersect
Step 4: The Tuck
Picture of The Tuck
The next step is the tuck.
While continuing to pinch the intersection of the two parts of the tie, you will take the broad end of your tie and stick it through the loop you made during the intersection when you crossed the tie in step 3
  • It is important that when you stick the broad end of the tie through the loop that you stick it through the loop from behind
Once you stick it through the loop pull the tie tight
  • When you are finished with this step you will see the initial formation of the knot being tied
BE SURE that you are still pinching the intersection of your knot or it will not come out right
Step 5: Cross Behind
Picture of Cross Behind
Once you have successfully completed your tuck, you can proceed to step 5, Cross Behind
In this step, you take the broad end of your tie and cross it to the opposite side, across your knot.
  • Whichever side the broad end of your tie was on first, once you complete the cross behind, your broad end of the tie will be on the opposite side.
BE SURE that you are still pinching the intersection of that original knot
Step 6: Cross in Front
Picture of Cross in Front
Once you completed step 5, you move on to the similar step 6, the Cross in Front.
After you completed the cross behind, the tie is on the opposite side of your body. With the cross in front, you're going to bring the tie back to the original side, covering your knot that you made
  • Make sure that you cover the knot to the tie, or it will come out looking sloppy
Again, BE SURE that you're still pinching your knot in the intersection of the two parts of the tie
Step 7: The Second Tuck
Picture of The Second Tuck
Once you completed the cross in front, you can go into your second tuck
Once your tie is crossed in front and the knot is being covered, you can go into your second Tuck. Just like your first tuck you go into the loop from behind.
BE SURE you are still gripping the intersection to your tie or the knot will become loose and sloppy
Step 8: Opening Up the Knot
Picture of Opening Up the Knot
Once you get passed the second tuck, you're almost home free
The next step is opening up the knot. Now this step is the most complicated out of all the steps. With the hand you're pinching the knot with, you're going to simply open up your front cross just enough so that you can slip the head of your tie into.
  • Try not to open up your front cross too big or the knot will become sloppy
  • At this time it is not necessary for you to continue to pinch the intersection where your knot is
Step 9: The Pull Through
Picture of The Pull Through
Once you have opened up your front cross and have initially started to push the head through, the next step is the pull through
With the opposite hand that you used to open up your front cross, use it to reach into the bottom of your knot and pull the head of the tie through the knot.
  • You are going to pull the head of the tie, until the tie won't go down farther
  • Make sure that you pull tight, so that you have a nice crisp knot
Step 10: Tidying Up
Picture of Tidying Up
Once you finish step 9, you're basically done. The final step of tying your Half Windsor knot is just straightening and puling up the knot.
To pull up your knot, you will take the tail of the tie in one hand, and grasp the knot of your tie in the other hand. While you pull down on the tail of your tie, you're going to hold your knot and raise it toward your neck.
Once you raise it to your neck, you can straighten your tie up
Once you finish this step, you have completed your Half Windsor knot
DIY Hacks and How Tos (author)2016-09-18
Great tutorial. I have needed to lookup how to tie a tie almost everytime I go to a formal event.
About This Instructable
128views
3favorites
License:
More by JordanR66:How to tie a Half Windsor Knot Neck Tie
Add instructable to:
