This decorative knot can be tied onto a cane, walking stick, hiking staff, used as a neckerchief slide/woggle for a scout, added to a flashlight, knife handle, sheath, fishing pole, etc. As with other Turk's Head knots and their variations, you may find yourself looking for many different things to tie them on and around...
If you've got the hang of tying this knot, you can give the three pass Gaucho knot a try. :)
More knotty stuff on my blog: Stormdrane's Blog
Visit Our Store »
Go Pro Today »
I'd like to start by saying that I love your videos. I really appreciate how much effort you put into these and how kind it is for you to share them with the world.
The question that kept recurring in my mind is what would happen if you doubled the base Turk's head knot? Would it double the finished Gaucho knot?
Thanks.
There are many variations that can be explored, but they can be a bit on the advanced side for many. ;)
There's a lot more 'technical' info on tying Turk's head variations, that is beyond the easier knot work that I know how to tie, but you can find out more from the knowledgeable folks on the forums at khww.net and igkt.net. :)
Tom Hall has a couple of knot books that are frequently referenced by some of those folks in the know, although I do not have them, they are on the *wish* list... ;)
I don't know of a tutorial showing this on longer knots, because the exact over/under sequence is going to vary by the leads in each knot, but when you try it, the pattern becomes visible if you're familiar with the smaller Gaucho. It's the same kind of thing with other Turk's head knot variations, like the pineapple, once you learn the smaller base knot, you can figure out the longer ones with some practice. Hope that helps. ;)
I've not sold knot work on ebay.
Makes an otherwise complicated knotwork LOOK very simple, and actually BE not TOO difficult!
I know I've seen the making of the paracord clamping threading needle thingie somewhere but my memory, and search-fu escape me.
any chance someone reading this can link?
Tying this can be done without it, but you spend a LOT more time tightening when you're done.
One
Two
Three
I often use a simple 'clay stylus' as a 'marlinspike' to tighten up knot work, and it has worked well enough for me, especially with smaller diameter cord.
If the lacing needle you use is long and sturdy enough, you can also use it to work the knot, to tighten it up. You can use anything similar like an awl, ice pick, metal chopstick, tips of hemostats or forceps, etc...
Some pocket knives have a built in marlin spike, but those are generally a bit larger for use with thicker rope sized cordage. And there are at least a couple of models of Swiss Army knives that have a marlinspike built in(Skipper, First Mate)... :)
the first one was the ible i was thinking of.
