3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Tie the Lanyard Knot
Many people including myself have had trouble following the Stormdrane youtube video on tying the lanyard knot so i have done some research and found the solution!
Step 1Materials
Materials
All you need is a reasonable length of para cord or whatever you wish to use.
25 comments
Apr 9, 2012. 6:09 PMcoolo52 says:
i made this but i cant tighten it to look like that. any tips?
Nov 8, 2011. 12:32 PMjolora says:
How does this work for tying a lanyard knot in the middle of a very long rope, say 100 feet, with other lanyard knots tied in it? I cannot see feeding that much rope through the loops as this demonstration shows.
Dec 2, 2011. 12:27 PMpootwaddle says:
jolora - one of the "tricks" to learn is to push a "bight" of cord through and then pull the long part through - fast and easy, with no extra twists to the cord.
-or-
wind the excess cord around a spool so you only have to pull a short bit through
each time....
Sep 23, 2011. 7:49 PMdp mac says:
i like, very good my apprentice
Sep 9, 2011. 6:38 AMpyrosniperfreak says:
BAM! Nailed it first try. Thanks a bunch! Great instructable!
Jul 24, 2011. 1:24 PMEsque says:
Absolutely the simplest, easiest tutorial for this knot I've found, and I've tried a few!!! Many thanks for posting this!!!
Jun 28, 2011. 1:21 PM- D says:
This is the best tutorial I've ever found. It even beats the videos easily. I couldn't get it with the others, it got with this one on the first try. Thanks for posting it.
Jun 19, 2011. 2:18 AMfurir says:
This was the easiest way to tie this knot I've seen so far. Thanks for the tutorial.
Feb 2, 2011. 3:19 PMLoenja says:
this is the best tutorial i have found on the web, the others are too confusing, great work
Jan 14, 2011. 10:36 AMadamtyoung says:
Hmmm. Having trouble tightening it to look like this. Any tips?
Dec 17, 2010. 9:02 PMbridgmicks says:
Thank you, thank you, thank you!
Nov 28, 2010. 2:55 PMekcan says:
These are the best instructions for the lanyard knot. Thank you so much!
Oct 6, 2010. 3:45 PMCivbert says:
Excellent. I've worked several approaches to this knot, and this one was the best.
Oct 6, 2010. 2:35 PMRebel Fan says:
Easiest instructions on it so far. Thanks!
Aug 28, 2010. 2:04 PMchi chi chippy says:
ive been trying to tie this buy non of the videos seem to deminstrate it without a hand in the way. thanks for the ible, best lanyard knot tutorial
Jul 12, 2010. 2:54 PMKuribosboots says:
(removed by author or community request)
Jul 14, 2010. 12:07 PMShiseiji says:
Eddy, thanks. Kuribosboots, as Stormdrain notes in his blog, there are many differences in how we all learn knots and there he provides several links to different lessons for this knot. Eddy has added another and obviously helped many. I find pictures with multi-colored strands and a single bend at a time helps my poor simple mind a lot. See if this helps: http://www.folsoms.net/knots/ Select "Fifty knots" on the left and then #27 I struggle with orientation more now than I used to. Age I guess. So I copied/pasted the pictures into PowerPoint (or Open Office Presenter) and then rotated them 180 degrees so the orientation is the same as if I was holding a completed sinnet band with the working ends running away from me.
Jun 5, 2010. 4:47 PMGIJohn says:
Thanks for the ring finger tip, makes it that much easier.
Apr 18, 2010. 6:09 PMhenhan says:
this is the best.tied it the first time!
Apr 13, 2010. 6:12 AMnk97 says:
Nicely done! I found out how to tie one, but with just one strand (without doubling it). Your 'ible showed me how to do it with two strands. Goog job.
Feb 9, 2010. 9:06 AMmaoddo says:
Great piece! I struggled with this knot for hours trying to follow  various instructions and videos. I was able to complete the knot the first time using this< Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:eddy14777
