How to Tie the Lanyard Knot by eddy14777
Featured
Many people including myself have had trouble following the Stormdrane youtube video on tying the lanyard knot so i have done some research and found the solution!
Step 6: Finishing
When you take it off your finger it should look like this.
Work out the slack by pulling on the bight and the two strands.
HempKnight says: May 11, 2013. 12:35 AM
Good going man, clear instructions, easy to follow, my lanyard (diamond) knot turned out absolutely perfect. many thanks bro!
craftyv says: Dec 27, 2012. 1:12 PM
I want to use this under a monkey's fist so I hope I can use the two strands leaving the fist as the bight. Here goes..
amijares castilleja says: Dec 6, 2012. 5:12 AM
Very helpfull
coolo52 says: Apr 10, 2012. 3:59 AM
coolo52 says: Apr 9, 2012. 6:09 PM
i made this but i cant tighten it to look like that. any tips?
jolora says: Nov 8, 2011. 12:32 PM
How does this work for tying a lanyard knot in the middle of a very long rope, say 100 feet, with other lanyard knots tied in it? I cannot see feeding that much rope through the loops as this demonstration shows.
pootwaddle says: Dec 2, 2011. 12:27 PM
jolora - one of the "tricks" to learn is to push a "bight" of cord through and then pull the long part through - fast and easy, with no extra twists to the cord.
-or-
wind the excess cord around a spool so you only have to pull a short bit through
each time....
dp mac says: Sep 23, 2011. 7:49 PM
i like, very good my apprentice
pyrosniperfreak says: Sep 9, 2011. 6:38 AM
BAM! Nailed it first try. Thanks a bunch! Great instructable!
Esque says: Jul 24, 2011. 1:24 PM
Absolutely the simplest, easiest tutorial for this knot I've found, and I've tried a few!!! Many thanks for posting this!!!
- D says: Jun 28, 2011. 1:21 PM
This is the best tutorial I've ever found. It even beats the videos easily. I couldn't get it with the others, it got with this one on the first try. Thanks for posting it.
furir says: Jun 19, 2011. 2:18 AM
This was the easiest way to tie this knot I've seen so far. Thanks for the tutorial.
Loenja says: Feb 2, 2011. 3:19 PM
this is the best tutorial i have found on the web, the others are too confusing, great work
adamtyoung says: Jan 14, 2011. 10:36 AM
Hmmm. Having trouble tightening it to look like this. Any tips?
bridgmicks says: Dec 17, 2010. 9:02 PM
Thank you, thank you, thank you!
ekcan says: Nov 28, 2010. 2:55 PM
These are the best instructions for the lanyard knot. Thank you so much!
Civbert says: Oct 6, 2010. 3:45 PM
Excellent. I've worked several approaches to this knot, and this one was the best.
Rebel Fan says: Oct 6, 2010. 2:35 PM
Easiest instructions on it so far. Thanks!
chi chi chippy says: Aug 28, 2010. 2:04 PM
ive been trying to tie this buy non of the videos seem to deminstrate it without a hand in the way. thanks for the ible, best lanyard knot tutorial
Kuribosboots says: Jul 12, 2010. 2:54 PM
(removed by author or community request)
Shiseiji says: Jul 14, 2010. 12:07 PM
Eddy, thanks. Kuribosboots, as Stormdrain notes in his blog, there are many differences in how we all learn knots and there he provides several links to different lessons for this knot. Eddy has added another and obviously helped many. I find pictures with multi-colored strands and a single bend at a time helps my poor simple mind a lot. See if this helps: http://www.folsoms.net/knots/ Select "Fifty knots" on the left and then #27 I struggle with orientation more now than I used to. Age I guess. So I copied/pasted the pictures into PowerPoint (or Open Office Presenter) and then rotated them 180 degrees so the orientation is the same as if I was holding a completed sinnet band with the working ends running away from me.
GIJohn says: Jun 5, 2010. 4:47 PM
Thanks for the ring finger tip, makes it that much easier.
henhan says: Apr 18, 2010. 6:09 PM
this is the best.tied it the first time!
eddy14777 (author) says: Apr 26, 2010. 3:19 PM
I'm glad i could help!
nk97 says: Apr 13, 2010. 6:12 AM
Nicely done! I found out how to tie one, but with just one strand (without doubling it). Your 'ible showed me how to do it with two strands. Goog job.
eddy14777 (author) says: Apr 15, 2010. 4:17 PM
maoddo says: Feb 9, 2010. 9:06 AM
Great piece! I struggled with this knot for hours trying to follow  various instructions and videos. I was able to complete the knot the first time using this< Thanks!
eddy14777 (author) says: Feb 9, 2010. 5:39 PM
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
