loading
Step 3: Starting the Knot
Make a loop just like the one in the picture and place it over the top strand.
Bring the top strand under the bottom strand.
<p>This is by far the easiest way I have seen to do this knot, thank you and well done!</p>
<p>Great ible!! Thank you!</p>
I've had trouble in the past with paracord coming undone when working at hights. this knot seems to hold a lot better. <br>I had a bit of trouble with the doubling but I got it in the end. <br>Helpful indestructible
Another instructable for this dog leash suggested your lanyard knot. Works great, though I ended up tightening it one string at a time for an extra tight knot. I also added some superglue so the two spare strands (the ones that are just going through the center) don't slip through and actually add support. Fantastic instructable.
<p>The second picture in step 5 is not clear enough, possibly because the picture is too small.</p>
done in 1. Excellent instructions, thanks very much.
The first couple of times I tied this knot, I came back to go over your steps. And I could not for the life of me figure out how to make this knot slide in order to tighten a lanyard or drawstring. Until I realized that this knot is the same one that I saw to put some cord on my water bottle and it hit me, I can just put my loop through the center of the knot! And now I can tie it without instruction. It is fast becoming my favorite knot. Thank you!
THANK YOU!! this is by far superior to what I have found online! Great Job!!!
Good going man, clear instructions, easy to follow, my lanyard (diamond) knot turned out absolutely perfect. many thanks bro!
I want to use this under a monkey's fist so I hope I can use the two strands leaving the fist as the bight. Here goes..
Very helpfull
<a href="http://www.youtube.com/watch?v=faO3rY9G_Ns&feature=relmfu" rel="nofollow">i personally think that stormdrane's video made sense. i was able to tighten the knot just because of watching his video and how he out the tips through the &quot;diamond&quot;, i guess it wouldnt look like that because i put the ends in wrong. i will admit that his video is a bit confusing but he does the same thing as you just with a slightly different method</a><br> <br> <br> <br>
i made this but i cant tighten it to look like that. any tips?<br>
How does this work for tying a lanyard knot in the middle of a very long rope, say 100 feet, with other lanyard knots tied in it? I cannot see feeding that much rope through the loops as this demonstration shows.
jolora - one of the &quot;tricks&quot; to learn is to push a &quot;bight&quot; of cord through and then pull the long part through - fast and easy, with no extra twists to the cord.<br><br>-or-<br>wind the excess cord around a spool so you only have to pull a short bit through<br>each time....
i like, very good my apprentice <br>
BAM! Nailed it first try. Thanks a bunch! Great instructable!
Absolutely the simplest, easiest tutorial for this knot I've found, and I've tried a few!!! Many thanks for posting this!!!
This is the best tutorial I've ever found. It even beats the videos easily. I couldn't get it with the others, it got with this one on the first try. Thanks for posting it.
This was the easiest way to tie this knot I've seen so far. Thanks for the tutorial.
this is the best tutorial i have found on the web, the others are too confusing, great work
Hmmm. Having trouble tightening it to look like this. Any tips?
Thank you, thank you, thank you!
These are the best instructions for the lanyard knot. Thank you so much!
Excellent. I've worked several approaches to this knot, and this one was the best.
Easiest instructions on it so far. Thanks!
ive been trying to tie this buy non of the videos seem to deminstrate it without a hand in the way. thanks for the ible, best lanyard knot tutorial
Thanks for the ring finger tip, makes it that much easier.
this is the best.tied it the first time!
I'm glad i could help!
Nicely done! I found out how to tie one, but with just one strand (without doubling it). Your 'ible showed me&nbsp;how to do it with two strands. Goog job.&nbsp;
I'm glad i could help!<br />
Great piece! I struggled with this knot for hours trying to follow&nbsp; various instructions and videos. I was able to complete the knot the first time using this&lt; Thanks!<br />
About This Instructable
399,888views
581favorites
License:
More by eddy14777:How to Tie the Lanyard Knot
Add instructable to:
