How to Tile a Fireplace
493
12
Published
Introduction: How to Tile a Fireplace
About: Find me on Facebook! https:www.Facebook.com/DIYwithCaitlin I'm a passionate DIYer and especially enjoy projects involving bottle cutting, candles, soap, home improvements and succulents.
Watch this short video and learn how to tile a fireplace!
Step 1: Gathering Supplies
When purchasing tile buy 10% more than you think you'll need. You'll consume a lot of tile when you have to start cutting up edges and the worst thing is being 75% done and running out of tile!
For this project you'll need:
  • 5 Gallon buckets (these are useful in the demo for hauling out tile and also to needed to mix mortar and grout)
  • Tile
  • Mortar (I used mortar on the floor tiles)
  • Wet Saw with diamond blade
  • Plastic sheeting
  • Notched trowel
  • Tape Measure
  • Various rags, brooms, dust pans
  • Grout (unsanded) Most people don't think about the grout, but the color you choose is really important!
  • Sealant
Step 2: Demo the Existing Tile
Here's an example of where having the right tool makes ALL THE DIFFERENCE. This baby jackhammer make demo a breeze (and honestly really fun and rewarding). If you're wondering if it's worth the rental fee at home depot, it is. Make sure to scrape any concrete and existing mortar off the floor before moving to the next step. You need a smooth surface. The concrete foundation can be thin, so be careful not to hammer down into it.
Step 3: Lay Your Tile
Make sure your fireplace area is completely cleared of debris.
If you're using a patterned tile lay it out and see where you want the pattern to display. I started from the face of the fireplace and went up from there. Make sure to give this step some thought before you dive in.
I started on the bottom right (front face) and worked my way up and out. Don't start laying tile in more than one place at a time or your pattern won't match up.
You'll also need to decide your spacing. For the floor tile I went with a 1/8" spacer. For the teal tile I tried to go 1/16" but the pattern was organic and the tiles varied in size so much that I ended up just eyeballing it.
Step 4: Mix Your Mortar and Place Tiles
Here's the fun (and exhausting) part. Start laying your tile! Spread your mortar on the surface. Start by spreading a thin layer covering the area and then go back with your notched trowel and drag the ridged edge across the mortar so you see rows of lines. This will help the tile stick.
Tip: Some areas of the wall may need more or less mortar to keep your tiles flat. I wanted to tile over some of the black box of the fireplace, which you can do if you keep the vents clear, that area was slightly recessed from the rest of the wall so I needed to add extra mortar so it would all be flush.
You'll also need to cut tiles to size using your wet saw. Make sure water is continuously running on the blade.
Step 5: Grout & Sealing
After all your tiles are placed (congrats!) it's time to grout. Follow the instructions listed on your bag of grout. I mixed the grout, applied using a trowel (hint or my hand), let sit for ~20 minutes and wipe off with a large damp sponge. Have a bucket of hot clean water handy to rinse out sponge. Make sure not to take too much grout out of your edges. Try to just remove the grout on the tile. Grout will become very hard in 24 hours.
You can seal the grout in a few days. Since this isn't bathroom tile it isn't necessary to seal right away.
Step 6: Enjoy Your Beautiful Handiwork!
Congrats! You did it!
Thanks for checking out my Instructable. Check out my YouTube channel for even more DIY videos. Or post your fireplace and DIY videos to my Facebook page. Happy DIY-ing! :)
PS! If you liked this video check out my kitchen remodel! I completed the whole project for less than $5000!
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    I love the tiles you chose, this looks really good!
    Thank you Swansong!!! It makes such a huge difference. I barely recognize my living room! :D
