How to Transfer an Image to Wood - Laser Vs. Inkjet
30,380
70
16
Posted
Introduction: How to Transfer an Image to Wood - Laser Vs. Inkjet
I have been looking for different ways to transfer my logo to the projects I make as a way of signing them.
I had read that laser prints are much better than inkjet prints when you try to transfer them. I decided to investigate and see if there was much of a difference.
I you would like to watch the video here it is:
Materials Used:
  • Laser Print on regular paper
  • Inkjet Print on regular paper
  • Modge Podge Image Transfer
  • Water
  • Spray Polyurethane
  • Wood to transfer too
'Tools' Used:
  • Clean Rag
  • Scissors
Step 1: Prepare the Image
Remember to flip your image before printing. Especialy if you have text on the image. If printed normaly the image will be back to front so it has to be flipped first.
If you dont want a white boarder around your image then remember to cut as close to the image as you can. You could experiment with different edge styles but I just prefer a clean cut look. White boards can look good though.
I cut out my logo on both the laser and inkjet version leaving no white paper showing.
Step 2: Apply Mod Podge Image Transfer
All I did next was to paint a thick (but not too thick) layer of Mod Podge image transfer onto the image itself. I could barely see the image through the white Mod Podge when I was done.
I could then apply the image to the piece of wood. I had split the wood to show the difference between laser & Inkjet versions. I placed both images face down and smoothed them out using my fingers to make sure they were flat and had no creases or bubbles. I could leave them to dry overnight.
Step 3: Remove Paper Backing
To remove the paper backing from the images all I did was use some clean water and a clean rag (I used a piece of old T-Shirt).
I lightly dampened the rag and wet the paper back of the images. I left them a short while to soak, then I began to lightly wipe away the wet paper from the image. Be careful at this stage because you could remove the image itself if you arent careful.
I removed a lot of the paper and left them to dry to see what was left. There was quite a bit of paper left behing so I repeated the previouse step of using the wet rag to remove the paper. I did this 3 times for the laser version and just twice for the inkjet version.
The laser print held up great but the inkjet version didnt. It began to fade very quickly and I wasnt able to remove the paper fully.
To seal the images to the wood I used spray polyurethane. This will help protect the images and stop them from peeling or getting scratched off.
I think you will agree that the laser version is a lot better quality when compared to the inkjet version. You can use an inkjet print though as you can see but I would highly recomend using a laser print if possible.
I hope you found this instructable useful.
  • So glad you did this...-JenniferG211
    JenniferG211 made it!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
On either do u need photo paper or any other special paper?
10 Comments
Oh wow! thank you. I don't think one is better than the other. I think I like the grainy look for some of my stuff but when I want a super clear image, I'm going laser.
I am an artist looking to incorporate image transfers into my work. I've been having issues with my ink jet printer (as your video demonstrated) and have been thinking about investing in a laser printer for this specific purpose. Your video not only answered my question regarding the viability of laser vs. ink jet, but reinforced my experience (I thought perhaps my technique needed adjustment. Or something.) Anyway, thank you! -Charlynn
Thank you Charlynn! Im glad you found it helpful. I had the same issue trying to find a simple comparison between ink jet and laser printer results. Ive since bought a laser printer myself, so far so good. I wish I had bought one sooner
Thank You Hun. Helped me out bunches ((HUGS))
Where the heck is the subscribe button ? Dang I'm blonde !!!
Thanks Cheryl! Im really glad you found it helpful :) I see that you have subscribed to me on here thank you! I hope you get some inspiration from what I make :) I also have a youtube channel if you're interested - www.youtube.com/user/AverageJoesJoinery
I wonder. Why have you cut the saw teeth? Was it because the image had a background color other than white?
The white also gets transfered to the wood. I didnt want a white background so I cut the shape out first :)
Great idea and good instructable.
A Xerox Phaser (solid ink) printer works even better than a laser due to its wax-based (waterproof) ink deposit. Unfortunately the printers are quite large (the size of an OLD laser printer) and expensive (generally $650 or more). A set of the solid ink blocks lasts a long time, but is normally over $100. However, if you know someone who has one and is willing to print you a few sheets of your logo....
Thanks! I had never heard of that type of printer before. I will have a look into it. It would be great if I could find an online printing serivce. I got an A3 sheet full of my logo's from an online poster printer. I dont know if my inkjet printer is just bad but the laser print was a alot better quality. I always thought inkjet was better for photo's. I will have to do some research before I commit to a new style of printer :) Thanks and again for the info, I really appreciate it :)
