How to Turn a Mic Stand into a Cymbal Stand by benfarhner
After completing my hi-hat stand successfully, I needed a stand for my crash cymbal. We happen to have accumulated a lot of mic stands (and, ironically, no mics), so I thought the easiest thing to do would be to repurpose one of those as a cymbal stand.
I spent less than $4 on hardware for this. I already had the mic stand and threaded rod, and the rest I bought from the local hardware store. The build was very simple and took me less than 5 minutes to put together.
Step 1: The Parts
You'll need the following parts for this build.
  • Mic stand with 3/8"-16 threaded end
  • 3/8"-16 x 6" threaded rod (could be as short as 3")
  • 3/8"-16 coupling nut
  • 3/8"-16 wingnut
  • 3/8" x 3/8" x 1" nylon spacer (2x)
  • 3/8" x 1-1/2" rubber washer (2x)
  • Crash or ride cymbal
Note: the mic stand I used had a removable end, revealing a 3/8"-16 thread (I got lucky). If you can't find a mic stand like this, the outer threads on mic stands appear to be pretty universal, so the workaround would be to use a different coupling that fits that larger diameter and use a reducer to fit the threaded rod. You may also need a finer threaded rod if that's the case.
Astronomicat says: Jun 14, 2010. 5:43 PM
I've got a pulse drum kit too!!!!!!!!!!!!!!!!!!!!!
grimfig says: Aug 8, 2010. 10:06 PM
That's definitely Pacific, not Pulse.
Astronomicat says: Aug 9, 2010. 7:45 PM
well all of the heads had the pulse logo, so... well it at least looks like the pulse logo
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
